jostim Groupie
| Posted: March 09 2007 at 14:46 | IP Logged
Experts,
I have another newbie question. I would like to use a low voltage signal (or a dry contact closure) as an input for PH.
Is there a cheaper solution than the Sarthome Input/Output Controller #31271? (http://www.smarthome.com/31271.html)
I only need one input to give a (any) signal to PH on contact closure, so I can have PH turn on the shop vac I use as a poor man's central vacuum system.
Any idea's?
thanks
__________________ - jos
ginigma Senior Member
| Posted: March 09 2007 at 15:10 | IP Logged
Wow, I've just been looking for the same. The SimpleHome Insteon module is too expensive for what I'm trying to do (garage door contacts). I saw that PH supports the Velleman 8000 and I've been searching all over for it, but it looks like it's a discontinued product.
I'm also looking for something supported by PH (Serial, Parallel or USB port) for input/output.
Charles
| Posted: March 09 2007 at 16:57 | IP Logged
I would suggest using a DS10A (or the new one at Radio Shack) X10 RF Security sensor. You would need a W800 or RFXCom unit, though.
Another option would be to hack an X10 controller and put the contact across one button's terminals.
| Posted: March 09 2007 at 19:29 | IP Logged
I'd really hate to add X10 to my system. Any other suggestions?
| Posted: March 09 2007 at 21:39 | IP Logged
FWIW, X10 RF is not X10.
X10 RF is rock solid.
jostim Groupie
| Posted: March 10 2007 at 08:03 | IP Logged
Tonyno,
Thanks for your suggestion. I was hoping to find a cheaper solution, but the W800RF32 opens up all kinds of (future) possibilities.
I have a number of DS10A's laying around waiting to contribute to my home automation. I guess I'll spend the money on the RF receiver.
thanks
jostim Groupie
| Posted: March 24 2007 at 17:46 | IP Logged
Update:
works great. At least it did, but than my PC died.
My automation will continue when I get my new PC.
thanks again.
