        | theowl Groupie
          I got a simple RSS parse working using ph_regex
           | Posted: June 13 2006 at 20:07 | IP Logged |   |
 insert into macroheader values ('RSS-GET','GRAB AND PARSE RSS FEEDS',0,0,1);
 insert into macrodetail values ('RSS-GET',2,15,'[GLOBAL1] ',NULL,'ph_geturl("http://blog.washingtonpost.com/securityfi x/index.xml")',0,'');
 insert into macrodetail values ('RSS-GET',3,15,'[GLOBAL1]',NULL,'ph_replaceallregex ("&....;","----", ph_getvar_s(3,1),2)',0,'');
 insert into macrodetail values ('RSS-GET',4,15,'[LOCAL2]',NULL,'ph_regexdiff ( "<title>", "</title>", ph_getvar_s(3,1),1,2) ',0,'');
 insert into macrodetail values ('RSS-GET',5,9,'',NULL,'"Site: [LOCAL2]"',0,'');
 insert into macrodetail values ('RSS-GET',6,15,'[LOCAL3]',NULL,'ph_regexdiff ( "<item>~255<item>", "</item>~255</item>", ph_getvar_s(3,1),1,2) ',0,'');
 insert into macrodetail values ('RSS-GET',7,15,'[LOCAL4]',NULL,'ph_regexdiff ( "<title>", "</title>", ph_getvar_s(1,3),1,2) ',0,'');
 insert into macrodetail values ('RSS-GET',8,15,'[LOCAL5]',NULL,'ph_regexdiff ( "<Description>", "</Description>", ph_getvar_s(1,3),1,2)',0,'');
 insert into macrodetail values ('RSS-GET',9,15,'[LOCAL5]',NULL,'ph_replaceallregex ( "\&+\;", "", ph_getvar_s(1,5),2)',0,'');
 insert into macrodetail values ('RSS-GET',10,16,'',NULL,'if(ph_getvar_s(2,1) = "",999,1)',1,'');
 insert into macrodetail values ('RSS-GET',11,9,'',NULL,'"Title: [LOCAL4]"',0,'');
 insert into macrodetail values ('RSS-GET',12,9,'',NULL,'"Description: [LOCAL5]"',0,'');
 insert into macrodetail values ('RSS-GET',13,16,'',NULL,'-5',1,'');
 I used [GLOBAL1] so the page would stay stored while I tested the ph_replaceallregex function. The issue I'm having is getting the regex to match more than one <item> on the page. Using <item>, it will match the first one, and if I use <item>~255<item> it will match the second. Do I really have to keep doing the 255 routine to go further down the page or does this function store the last search position somewhere so I can start from where it left off?
 Anyone?
        | TonyNo Moderator Group
          Take a look at my Weather Warnings macro for how to do this. It also parses <item> tags.
           | Posted: June 13 2006 at 20:29 | IP Logged |   |
        | theowl Groupie
           | Posted: June 15 2006 at 14:58 | IP Logged |   |
 I imported that and it worked great. However, it's above my PH knowledge. From what I can decode, it looks like your doing a multi-search...but that's as far as I could factor.
 I did find an activeX helper that gives VBscript the ability to handle all versions of RSS (I hope). I'm working on a little script using that.
 So far, I can just feed the script a URL, channel to access, and item I want. Once I get the error checking correct and make the PH modification... PH should be able to easily handle everything else.
          Owl,
           | Posted: June 16 2006 at 14:37 | IP Logged |   |
 Keep us posted on your progress.  We don't have too many people exercising the VBScript capabilities of PowerHome so would love to see what you're doing.
 Also, the next beta will include some additional regex functions to hopefully make searches easier.
        | theowl Groupie
          Will do
           | Posted: June 17 2006 at 15:30 | IP Logged |   |
 Most of the script is just error checking stuff, the actual action code is quite small.
 It's nice to have the VBscript ability in PH because I can write and debug those type of scripts at work if I'm bored. Then e-mail them to the automation system, drop in place, and away it goes.
