        | phil13 Groupie
          How to make a timed event that run every 10 minutes ?
           | Posted: December 20 2004 at 11:04 | IP Logged |   |
 I did't see fequency under one hour ...
          Phillipe,
           | Posted: December 20 2004 at 17:03 | IP Logged |   |
 Just type 10 in the frequency box.  You can set the frequency in minutes to whatever value you like by just typing it.  The dropdown is actually just some common values for convenience.  If you actually wanted a timed event to fire every 30 seconds, you could set the frequency to 0.5.
        | phil13 Groupie
          OK thanks.
           | Posted: December 20 2004 at 23:21 | IP Logged |   |
 I've never thought i coul't type somethething in in frequency box ...
