device Newbie
| Posted: October 06 2013 at 11:59 | IP Logged
For various reasons over time the PH database became out of sync with the actual devices. So this morning I wrote a VBScript to synchronize the two. There may be easier ways I am unaware of to do this. I use VbsEdit for writing and basic "out of PH" debugging so the Include procedure and "phstub.vbs" script establish a stubbed PH execution environment to facilitate debugging. Anyway thought someone might find it useful / interesting.
D
Option Explicit
Sub Include(sInstFile)
On Error Resume Next
Dim oFSO, f, s
Set oFSO = CreateObject("Scripting.FileSystemObject")
If oFSO.FileExists(sInstFile) Then
Set f = oFSO.OpenTextFile(sInstFile)
s = f.ReadAll
f.Close
ExecuteGlobal s
Else
MsgBox sInstFile & " does not exist", 0
End If
Set oFSO = Nothing
Set f = Nothing
End Sub
Sub getdevices()
Dim sql, sqlstat, rows, cid, index, doupdate, id, iengine, usexaldb, realiengine
sql = "SELECT id, iengine, usexaldb FROM insteondevices where address <> '00.00.00'"
sqlstat = ph.sqlselect(1, sql)
rows = ph.getsqlrows(1)
cid = ph.getglobal_s("CONTROLLER ID")
For index = 1 To rows
doupdate = 0
id = UCase(ph.getdata(1, CLng(index), CLng(1)))
If (id <> cid) Then
iengine = CLng(ph.getdata(1, CLng(index), CLng(2)))
usexaldb = CLng(ph.getdata(1, CLng(index), CLng(3)))
realiengine = CLng(ph.insteonwithret(id, 13, 0))
If (realiengine < 0 Or realiengine > 2) Then
Call ph.usermessage("Get Iengine for " & id & " failed with return code " & realiengine)
Else
If (iengine >= 0 And iengine <= 2 And usexaldb >= 0 And usexaldb <= 1) Then &n bsp;
If (realiengine <> iengine) Then
Call ph.usermessage(id & " update iengine from " & iengine & " to " & realiengine)
doupdate = 1
End If
If (realiengine > 0 And usexaldb <> 1) Then
Call ph.usermessage(id & " update usexal dbfrom " & usexaldb & " to 1")
usexaldb = 1
doupdate = 1
End If
If (doupdate = 1) Then
sql = "UPDATE insteondevices SET iengine = " & realiengine & ", usexaldb = " & usexaldb & " WHERE id = '" & id & "'"
Call ph.usermessage(sql)
Call ph.directsql(sql)
End If
Else
Call ph.usermessage(id & " unknown database values iengine = " & iengine & " usexaldb = " & usexaldb)
End If
End If
End If
Next
ph.sqldestroy(1)
End Sub
'Call Include("phstub.vbs")
'Call getdevices()
