rtt3821 Newbie
| Posted: September 07 2009 at 20:02 | IP Logged
I'm trying the trial version and am a real dummy when it comes to C#. I want to turn ON a motor at 0900 and OFF at 1700 between November 1st and April 30th. I cannot seem to get the formula right. Can anyone help?
| Posted: September 07 2009 at 20:30 | IP Logged
Welcome aboard!
What technology are you using, i.e. UPB, Insteon?
...and you don't need to know C#.
Edited by TonyNo - September 07 2009 at 20:31
rtt3821 Newbie
| Posted: September 08 2009 at 12:14 | IP Logged
I'm using Insteon.
| Posted: September 08 2009 at 13:44 | IP Logged
You can create a PowerHome Timed Event using the Powerhome Explorer. Have it fire on a daily basis starting Nov 1, 2009 09:00. Use a Type of Raw Formula, the ID field would contain ph_macro("YOURMACRONAME"), and the following formula in the Boolean field...
if((month(today()) >= 11 and month(today()) <= 12) or (month(today()) >= 1 and month(today()) <= 4), 1 , 0)
EDIT: a case statement is less involved than if ...
case( month(today()) WHEN 11,12,1,2,3,4 THEN 1 ELSE 0 )
The Timed Event will invoke the macro only if the month is Nov, Dec, Jan, Feb, Mar or April. The macro will have the Insteon command(s) to control whatever you want to accomplish at 9:00 AM. Code a second Timed Event that fires on a daily bases starting Nov 1, 2009 17:00, invoking the same or different macro to accomplish what you want to do at 17:00. You can code logic in the macro to determine time of day so that you do On versus Off logic or code two different macros, one for On logic and one for Off logic.
There are many ways to implement something in Powerhome. This is only one of many approaches.
Edited by grif091 - September 08 2009 at 19:59
rtt3821 Newbie
| Posted: September 08 2009 at 14:35 | IP Logged
Thanks grif091. I will give it a go! Sure appreciate the help.
