           | Posted: January 23 2009 at 09:26 | IP Logged
I've written a lot of code in my day, except for two things.... I never got to write any IBM/360 machine code, nor any SQL code, thus a pretty basic question here, but one I don't see answered anywhere in the forum nor can I find any PH doco that explains.
 The forum is full of macro examples that are in the form of "insert into macroheader values" etc statements.
 Per se these are almost impossible to read and understand as macros as there is also SGL info embedded in the lines.
 How does one take these examples (Copy) and Paste them into PH.  I assume the Multi-Editor is the tool, but what exactly are the steps to take these examples and get them into PH where they can then be looked at in the Macros area of PH Explorer, so they can be understood and used?
           | Posted: January 23 2009 at 10:06 | IP Logged
Well I’ve written a lot of 360 Assembler and know how to read machine language dumps and have no SQL experience. Said that it does not help me with PH. Trial and Error and experience are my best tools. If someone has exported a macro to the forum and you want to import it then you copy it to the Multi-Editor as you said. Once it’s there then go to Edit and Execute Script. It will be in your Macro list.
 EDIT: Thks Noel
  Edited by BeachBum - January 23 2009 at 10:40
         nadler Super User
           | Posted: January 23 2009 at 10:12 | IP Logged
Copy and paste to the multi-editor.  A second tool bar
 appears with all the multi-editor's functionality.  Make
 sure you are in SQL as opposed to the other options.
 Click on execute and viola the macro will appear in you
 list of macros.  If you click execute a second time you
 will get an error message indicating the macro name is
 already being used.
 Noel
           | Posted: January 23 2009 at 15:06 | IP Logged
Thanks.  That worked.
 How about the inverse to this action?  What does one do
 to be able to share macros.  I don't spot a SQL Export
 function in the editor.
           | Posted: January 23 2009 at 16:15 | IP Logged
"Export" right click in the right pane.
           | Posted: January 24 2009 at 07:16 | IP Logged
Pete - Right-Click in what pane?
 It is not the macro window, unless I'm not seeing all the context menue items there for some reason.
 If it is the Multi-Edit SQL window then I'm still stumped as my question is how do you get the SQL sequences in the first place.
 That is if all I have is a macro, how do I turn it into an SQL sequence to share with others?
           | Posted: January 24 2009 at 08:49 | IP Logged
You Export the macro from the top Macros window by right clicking on the macro name in the list in the right-pane.
 In the PH Explorer, click on Macros.
           | Posted: January 24 2009 at 09:59 | IP Logged
Ken, sorry for the lack of detail. PH Explorer – left click on Macros (name NOT plus) – right click on the Macro (name) and select Export. You will be given an opportunity to Save As.
