           | Posted: January 16 2009 at 21:52 | IP Logged
In setting up Triggers to synchronize my various KPLs
 and multi-way switch status lights instead of having to
 link them all, I want to track sync'd units as
 reasonably as possible but hate to keep sending
 ph_getinsteonlevelrt commands all the time to keep comm
 traffic down.
 If things track reasonably well, I'd just as soon use
 the ph_getinsteonlevel command but when is it updated?
 Specifically when a devices changes state (on/off/dim)
 is the PH data base status also changed, or does the db
 wait for the next poll of the device (which might be
 several minutes later)?
 When I turn a light on, I'd like for the KPL button and
 multi-way switches also linked thereto to track the
 light's status.  Clearly the real-time level check I can
 fire from a Trigger will do it, but it seems overkill if
 the db is itself updated by the device status change(in
 which case the non RT level check command is quite
 adequate).
