| Posted: August 22 2008 at 10:28 | IP Logged
I’m trying to position on an asterisk using POSW( "[LOCAL1]", " * " ) but it is not making a match. What code trick do I need to use to find it?
jbbtex Senior Member
| Posted: August 22 2008 at 11:21 | IP Logged
Maybe try chr$(42)?
__________________ Brady
| Posted: August 22 2008 at 11:31 | IP Logged
Doesn't work either...
| Posted: August 22 2008 at 11:59 | IP Logged
Pete,
The code you posted has spaces between the qoutes and the *. When I pasted this into a test macro, it didn't work.
When I removed the spaces it did work.
| Posted: August 22 2008 at 12:06 | IP Logged
Thanks Brady… Interesting, when I removed the leading blank it worked. I thought the data had a blank as 1st character.
Thanks for your help….
