doctorjerry Groupie
Online Status: Offline Posts: 57
Posted: March 06 2008 at 11:10 | IP Logged
I'd like to try using the Control Center. In my database nothing is defined under Control Center in Powerhome explorer. Pressing Alt-F1 brings up an empty screen.
After opening the phsample.db, Powerhome explorer shows multiple control center details, but the Control Center window is still blank.
Where do I begin?
__________________ Jerome
jbbtex Senior Member
Posted: March 06 2008 at 12:55 | IP Logged
Go to the Control Center and righ click. Select Design View. This will open a new window where you can add buttons, labels and graphics. All this is controlled via Control Center Object Properties box which should be visible on the screen when you get into Design View.
Edited by jbbtex - March 06 2008 at 12:56
__________________ Brady
rogerxw Newbie
Posted: November 12 2008 at 14:23 | IP Logged
I opened the Control Center. The right click doen't do anything. Does the evaluation copy prohibit the use of Control Center?
rogerxw Newbie
Posted: November 12 2008 at 14:37 | IP Logged
Never mind. I have to use the wizard to create one first.
doctorjerry Groupie
Posted: November 23 2008 at 23:56 | IP Logged
Roger,
What wizard are you referring to. I still haven't been able to use Control Center.
Jerry
Posted: November 24 2008 at 07:15 | IP Logged
PH2 has a CC wizard that sets up basic screens to control your defined devices. Hitting the star button on the toolbar will start it.
doctorjerry Groupie
Posted: November 24 2008 at 12:21 | IP Logged
I'm using v.1.03. I guess I need to upgrade. Correct?
Posted: November 24 2008 at 13:40 | IP Logged
Yup.
MrGibbage Super User
Posted: November 28 2008 at 11:19 | IP Logged
Right click doesn't do anything for me either. I also went into the wizard and created a new 640x480 control center page, and it said it was successful, but when I went back to PH, the control center was still blank, even after restarting it.
