ginigma Senior Member
Posted: February 13 2008 at 22:00 | IP Logged
I'm using month (today()) which returns "2" for this month. How can I get it to return "02", meaning I always want 2 chars returned, so if the month is < 10, pad it with a "0"?
Posted: February 13 2008 at 22:24 | IP Logged
First, be careful. Month returns a number, not a string. Since you want a leading zero, this is a string...
if( month(today())<9, string( month(today()), "00"), string(month(today())) ) |
JaredM Newbie
Posted: February 13 2008 at 22:25 | IP Logged
or just
string(month(today()),"00") |
will work for single and two-digit months.
Edited by JaredM - February 13 2008 at 22:26
Posted: February 13 2008 at 22:49 | IP Logged
Well, sure, but mine looks more complicated!
Posted: February 15 2008 at 00:01 | IP Logged
Ok Tony, I'll give you a chance to redeem yourself
Now it's the ph_run command.
This
ph_run ("dir > c:\temp\mmm") |
returns -1, but I can't figure out the error. Is it taking the greater than sign literally instead of redirection?
ph_run ("dir " + char (62) + " c:\temp\mmm") |
returns -1 also.
Thoughts?
Posted: February 15 2008 at 07:07 | IP Logged
Heh. Here you go...
ph_run('cmd.exe /c ~"dir > "c:\dir.txt"~"') |
Posted: February 15 2008 at 15:24 | IP Logged
You Sir, are a PowerHome God!
Now, for bonus points: Which is more efficient in a macro: the ph_run formula or Launch App command?
Posted: February 15 2008 at 16:32 | IP Logged
I would simply say that, with the formula, you'll have a return code that you can do something with.
