mustangcoupe Super User
| Posted: December 28 2007 at 17:48 | IP Logged
How do you configure the UDP Broadcast server? I am trying to get PH and ehomecreations working...
HA newbie
PowerHome - UPB - ELK
| Posted: December 28 2007 at 17:51 | IP Logged
I guess my real question is what are the IP address settings for? the eh server? can it boradcast to the entire network? would this be a good idea?
HA newbie
| Posted: December 28 2007 at 19:11 | IP Logged
The address settings are what PH uses for broadcasting. The defaults should be fine; just enable it. Yes, it broadcasts everything to the entire network.
cmhardwick Senior Member
| Posted: December 28 2007 at 20:09 | IP Logged
the first 3 octets must match the first 3 octets of your home network. By default, most routers are set the 192.168.0, but some people, like me, change that . Just set the IP addresses to match your PH web address, but leave the 255 at the end.
In my case, 192.168.10.2 is my PH machine, so all the UDP IP addresses would be 192.168.10.255
| Posted: December 29 2007 at 08:39 | IP Logged
Thanks, guys... I am also not on the 192.168.0.X so I will chane this to match.
HA newbie
