        | jostim Groupie
          I have a program I can't get to work.  It boils down to the following formula.  I added the "ph_rtne (ph_setvar_a (1,1,8)) +" to make it work inside this one formula:
           | Posted: August 19 2007 at 11:57 | IP Logged |   |
 ph_getglobal_s (
 "AV CHANNEL " + string ([LOCAL1],"00")
 RESULT (from Verify): !
 I then make the following change (comment out lines 2 and 4).
 /*ph_getglobal_s (*/
 RESULT (from Verify):!
 Next I ad quotes to [LOCAL1], now I get a result, but I expect the result “AV CHANNEL 08” and I get “AV CHANNEL 00”
 "AV CHANNEL " + string ("[LOCAL1]","00")
 RESULT (from Verify): AV CHANNEL 00
 Now I remove the quotes again and get the result I feel I should get:
 RESULT (from Verify):: AV CHANNEL 08
 Now I remove the comments from lines 2 and 4
 ph_getglobal_s (
 RESULT (from Verify): content of [LOCAL1]
 YES! It works!
   Now I close the formula and open it again, and I am back to square one: RESULT: !.
   What am I missing here?  Any ideas anyone?
 - jos
        | TonyNo Moderator Group
          You have a bunch of Globals called "AV CHANNEL xx" and are trying to get their contents?
           | Posted: August 19 2007 at 12:37 | IP Logged |   |
        | jostim Groupie
          Exactly.
           | Posted: August 19 2007 at 17:44 | IP Logged |   |
 |  They are the names and web addresses of radio stations I listen to using Winamp.
 I should have explained that better.
 - jos
 - jos
          Try this
           | Posted: August 19 2007 at 17:54 | IP Logged |   |
| Code:
       | ph_rtne(ph_setvar_a(1, 1, 8)) + ph_getglobal_s( "AV CHANNEL " + string( ph_getvar_n( 1, 1), "00")) |  |  |  |
        | jostim Groupie
          That did the job.
           | Posted: August 19 2007 at 22:52 | IP Logged |   |
 - jos
 - jos
