        | Tomcat7194 Newbie
          Hey everyone. I'm trying to run a pretty simple bit of code, and for some reason it's not cooperating. Basically, I want a macro that checks the global variable HEATON, and if it equals 1, changes it to zero, runs and x10 command, and does a tts.
           | Posted: February 01 2007 at 22:06 | IP Logged |   |
 Here is the code:
 Formula | Immediate| if({HEATON}=1, ph_x10btn ("3", 3, 0 ) + ph_tts("Furnace is on") + ph_setglobal_s("HEATON","0"), 0)
 When I run it with HEATON set to 1, it does not chance HEATON to zero, and it doesn't do the other functions. Any idea what I'm doing wrong here?
 Tom
        | Viper Groupie
          Use:
           | Posted: February 01 2007 at 22:26 | IP Logged |   |
 |  Goto Label | if ({HEATON}=1, "HEATON", "HEATOFF")
 Label | HEATON
 Set Global | "HEATON" | 0
 Formula | Post | ph_x10btn("3",3,0)
 Formula | Post | ph_tts("Furnace is on")
 Label | HEATOFF
          Tom,
           | Posted: February 07 2007 at 21:58 | IP Logged |   |
 I pasted your formula in the Multi-Editor and it worked just fine (once I created a global variable called HEATON and changed the "3" in ph_x10btn to match an X10 device in my setup) so Im not sure what the problem would be.  All of the functions you're calling return integers so that is not a problem with adding them together.  Have you any additional info to add?
 You could also use Vipers suggestion.  It should work as well.
