        | swany Newbie
          Well I don't know if this is even somthing that you would be thinking of but it would be nice.
           | Posted: August 19 2005 at 18:36 | IP Logged |   |
 |   I did not relize that the 8000 was serial and thought this would work.  Thats what I get for thinking.
 Swany
          Well...it looks like it would be doable.  It appears that they supply a nice DLL for interface communications (unlike the K8000 where I had to write the I2C routines from scratch).
           | Posted: August 19 2005 at 20:12 | IP Logged |   |
 It would be a little ways off however.  It would definately be after Insteon, UPB, and CM15A.
 So don't rule it out.  It looks interesting enough that I'll put it on the to-do list.
        | swany Newbie
          Dave; just currious
           | Posted: October 17 2006 at 15:31 | IP Logged |   |
 |   if you have given this any more thought?
 Swany
          Swany,
           | Posted: October 17 2006 at 16:11 | IP Logged |   |
 I havent gotten anywhere with this yet
  .  I still plan on doing it however, but it would probably end up in Q1 2007.
        | swany Newbie
          Any
           | Posted: October 20 2007 at 14:39 | IP Logged |   |
 |   yet or still  Just wondering..
 Swany
          Swany,
           | Posted: November 05 2007 at 13:38 | IP Logged |   |
 Sure missed that date didnt I
 If you've already got this device, I know that an xPL driver is available for it.  With the new PowerHome xPL plugin, you should be able to at least control and read this device.  The xPL controller is also in the works and will make this much simpler in the next version.
 If you've already got an 8055, would it be possible for you test it's operation using the current xPL plugin?
