        | TonyNo Moderator Group
          Any way to support ph_playsound and ph_tts in DCC? This would be great for distributed announcements and such.
           | Posted: February 19 2005 at 16:06 | IP Logged |   |
          Well ph_playsound is definately no problem...not sure why I didnt include it in the first place.  TTS on the other hand is a little more involved and would require the user to install the TTS modules.  I'll look into it though since it would be really handy for remote TTS capabilities.
           | Posted: February 21 2005 at 13:37 | IP Logged |   |
 I'll release a new version of the DCC shortly after the next beta.
          Great, thanks Dave!
           | Posted: February 21 2005 at 20:32 | IP Logged |   |
 Tony
          OK, what about an OSD function? Pop up messages and such, maybe even use graphics?
           | Posted: July 12 2005 at 22:59 | IP Logged |   |
           | Posted: July 18 2005 at 15:29 | IP Logged |   |
 Are you talking about an OSD for the DCC?  If so, would PowerHome need to process the returns from these messages?
 Would the graphics be located on the DCC machine or the PowerHome machine?
          Yup. An OSD for DCC. Processing returns would not be necessary.
           | Posted: July 18 2005 at 16:12 | IP Logged |   |
 As far as the graphics go, I could live without them, but it would be cool if they could live on the PH machine.
 I've done some research and only come up with one available option (YAC). This works, but the options need to be set in the registry!
           | Posted: August 10 2005 at 21:30 | IP Logged |   |
 Im trying to think of something generic and Im thinking about using the IE web browser control.  Basically, you could cause the DCC to open a window (you control size and position) without a toolbar, etc. that would then open a page (that you passed in the function) on the PowerHome server.  That way, the graphics and even intelligence could reside on the PowerHome server and the page could be as simple or detailed as necessar.
 Do you think this would server your purpose?
        | krommetje Super User
          Hi Dave...
           | Posted: August 11 2005 at 04:26 | IP Logged |   |
 That would open a lot of possibilities....
 Peter
 Edited by krommetje
          I think that would do nicely!
           | Posted: August 11 2005 at 08:56 | IP Logged |   |
           | Posted: August 11 2005 at 20:09 | IP Logged |   |
| Quote:
       | Im thinking about using the IE web browser control |  |  |  Does that need IE, or can it be just the default browser?
          The Microsoft Web Browser control is built into the OS, but uses IE.  It's the same control that appears in the PowerHome client as the "Web Center".
           | Posted: August 12 2005 at 13:50 | IP Logged |   |
