| Posted: April 22 2006 at 11:00 | IP Logged
I think I discovered something. X10 RAW does not work in a macro. I used it to turn a virtual device on and off with no luck (it use to work). Changing to it X10 works.
I also think this just applies to virtual devices, as "real" devices seem to work with X10 RAW commands.
| Posted: April 24 2006 at 16:05 | IP Logged
Could you provide me the details on the macro and the virtual X10 device?
I just tried a quick test with a new virtual device (Z1) and a new test macro. I used two X10 Raw commands (Z1 and ZON) and tested using the controller assigned to the Z1 virtual device, a different controller, and a blank controller (all within the X10 Raw command). Everytime it performed as expected.
Let me know,
| Posted: April 24 2006 at 19:41 | IP Logged
I switched it back to X10 RAW, and it worked this time. Maybe a conversion issue from the last upgrade?
Oh, well. Thanks for checking!
