| Posted: June 21 2009 at 14:07 | IP Logged
When the following statement is run through the Formula Builder the first 6 lines of the Insteon Raw Log are generated. Things look as expected. The two devices are queried and a response is received from each.
When this statement is executed as the Boolean field of a Trigger there are 6 TX lines in a row in the Raw Log reflecting 3 queries to each device, with a consistent 30 second delay from the first TX query to the first device before the RX lines are put into the Raw Log.
IF (ph_getinsteonlevelrt ("WINE BOTTLE LAMPLINC") >0 OR ph_getinsteonlevelrt ("ICON SWITCH TEST") >0, 1, 0)
2009-06-21 12:43:47.687 TX &nbs p; 02 62 04 90 07 05 19 00
2009-06-21 12:43:47.718 RX &nbs p; SENTINSTEON=0F 44 DC 04 90 07 05 19 00 06
2009-06-21 12:43:48.312 RX &nbs p; RECEIVEINSTEONRAW=04 90 07 0F 44 DC 22 00 00
2009-06-21 12:43:48.343 TX &nbs p; 02 62 04 56 50 05 19 00
2009-06-21 12:43:48.375 RX &nbs p; SENTINSTEON=0F 44 DC 04 56 50 05 19 00 06
2009-06-21 12:43:48.578 RX &nbs p; RECEIVEINSTEONRAW=04 56 50 0F 44 DC 21 00 00
2009-06-21 12:44:01.625 RX &nbs p; RECEIVEINSTEONRAW=0C AE 5F 00 00 01 CB 13 00
2009-06-21 12:44:02.000 RX &nbs p; RECEIVEINSTEONRAW=0C AE 5F 0F 44 DC 41 13 01
2009-06-21 12:44:04.500 RX &nbs p; RECEIVEINSTEONRAW=0C AE 5F 00 00 01 CB 11 00
2009-06-21 12:44:04.562 TX &nbs p; 02 62 04 90 07 05 19 00
2009-06-21 12:44:09.562 TX &nbs p; 02 62 04 90 07 05 19 00
2009-06-21 12:44:14.562 TX &nbs p; 02 62 04 90 07 05 19 00
2009-06-21 12:44:19.562 TX &nbs p; 02 62 04 56 50 05 19 00
2009-06-21 12:44:24.562 TX &nbs p; 02 62 04 56 50 05 19 00
2009-06-21 12:44:29.562 TX &nbs p; 02 62 04 56 50 05 19 00
2009-06-21 12:44:34.578 RX &nbs p; SENTINSTEON=0F 44 DC 04 90 07 05 19 00 06
2009-06-21 12:44:34.593 RX &nbs p; RECEIVEINSTEONRAW=04 90 07 0F 44 DC 22 00 00
2009-06-21 12:44:34.625 RX &nbs p; RECEIVEINSTEONRAW=0C AE 5F 0F 44 DC 6B 11 01
2009-06-21 12:44:34.671 RX &nbs p; RECEIVEINSTEONRAW=0C AE 5F 0F 44 DC 6B 11 01
2009-06-21 12:44:34.718 RX &nbs p; RECEIVEINSTEONRAW=0C AE 5F 0F 44 DC 6B 11 01
2009-06-21 12:44:34.781 RX &nbs p; SENTINSTEON=0F 44 DC 04 90 07 05 19 00 06
2009-06-21 12:44:34.796 RX &nbs p; RECEIVEINSTEONRAW=04 90 07 0F 44 DC 21 00 00
2009-06-21 12:44:34.828 RX &nbs p; SENTINSTEON=0F 44 DC 04 90 07 05 19 00 06
2009-06-21 12:44:34.843 RX &nbs p; RECEIVEINSTEONRAW=04 90 07 0F 44 DC 22 00 00
2009-06-21 12:44:34.875 RX &nbs p; SENTINSTEON=0F 44 DC 04 56 50 05 19 00 06
2009-06-21 12:44:34.890 RX &nbs p; RECEIVEINSTEONRAW=04 56 50 0F 44 DC 21 00 00
2009-06-21 12:44:34.921 RX &nbs p; SENTINSTEON=0F 44 DC 04 56 50 05 19 00 06
2009-06-21 12:44:34.937 RX &nbs p; RECEIVEINSTEONRAW=04 56 50 0F 44 DC 21 00 00
2009-06-21 12:44:34.968 RX &nbs p; SENTINSTEON=0F 44 DC 04 56 50 05 19 00 06
2009-06-21 12:44:34.984 RX &nbs p; RECEIVEINSTEONRAW=04 56 50 0F 44 DC 21 00 00
If the IF command is put into quotes ….
‘IF (ph_getinsteonlevelrt ("WINE BOTTLE LAMPLINC") >0 OR ph_getinsteonlevelrt ("ICON SWITCH TEST") >0, 1, 0)’
the first TX query has the result posted in the Insteon Raw Log immediately and is not retried.
Not sure if this is a bug or just a requirement that the Boolean field commands be quoted.
