PowerHome Bug Reports
Subject Topic: PowerHome 1.02.1 Upgrade Utility Bug Post ReplyPost New Topic
Posted: November 03 2002 at 22:51 | IP Logged Quote dhoward
A bug exists in the PowerHome version 1.02.1 upgrade utility if you are upgrading from a version prior to database version 1.01.1.  If you have kept up with the PowerHome upgrades, you should not have a problem.  The Utility only has a problem if your database version is prior to version 1.01.1.  If this is the case, you can download the corrected PHUPG.EXE from the Other Downloads page.  If you have already executed the faulty Upgrade utility and received an error, then you will have to rename your "pwrhome.XXX.db" file back to "pwrhome.db" before running the corrected utility.
kfoster01
Posted: August 03 2003 at 02:06 | IP Logged Quote kfoster01
I have tried this new upgrade utility but I am still getting an error message: Powerhome is currently running. Please exit powerhome and restart. Powerhome is not running. Tried uninstalling the program and reinstalling but the same result.
Back to Top View kfoster01's Profile Search for other posts by kfoster01
kfoster01
Posted: August 03 2003 at 02:12 | IP Logged Quote kfoster01
I am also unable to uninstall version 0.0.11 - error message: The operating system is not adequate for running Powerhome. Running win XP Pro
kfoster01
Posted: August 03 2003 at 13:35 | IP Logged Quote kfoster01
I have tried using the utility but have been unsuccessful, still geting error message that powerhome is running. Can I install the Latest version of Powerhome without upgrading and still keep my current lic? I will rebuild the database.
Posted: August 03 2003 at 21:00 | IP Logged Quote dhoward
Wow!!  That is an old version.  The error message you are getting is most likely due to you launching the upgrade utility from a folder named "PowerHome".  The upgrade utility searches for any open windows labeled "PowerHome" and assumes that PowerHome is currently running.  Try launching the upgrade utility by clicking on the "Start" button and selecting "Run...".  This should get you past the "PowerHome is already running" message.
If this still doesnt work...you have two options.  You can install the new version and start from scratch.  Just email me your new reg number and I'll send you the unlock key.  Or...you can email me your current database file and I'll manually upgrade it for you if you don't want to lose any of your setup.
Since you are upgrading from an older database, be sure and read the upgrade notes for any manual changes you may have to make.
Let me know how it goes and what I can do to help you.
kfoster01
Posted: August 03 2003 at 21:27 | IP Logged Quote kfoster01
Thank you Dave for all your help. I was successful in getting the upgrade utlility to run. Thank you again!!
