Subject Topic: PC-Hardware Trigger Post ReplyPost New Topic
Posted: July 04 2002 at 11:40 | IP Logged Quote TonyNo
Does PH support any triggers from PC hardware? I would like to have my doorbell tied in somewhere to be a trigger and not have the "wireless" delays.
Posted: July 05 2002 at 22:59 | IP Logged Quote dhoward
Not at this time. I plan to implement this type of support shortly via Windows messaging. Basically, external applications will be able to communicate via Windows messaging with PowerHome including activating triggers. An external program can then monitor whatever hardware ports, etc. is needed and then send the appropriate windows message to PowerHome and fire the trigger. Ive started work on it, but it wont make it into the next release.
Posted: July 07 2002 at 11:12 | IP Logged Quote TonyNo
Thanks for the info!
How's the next release coming along?
Tony
Posted: July 10 2002 at 20:09 | IP Logged Quote dhoward
I guess its been two weeks huh? It's coming along. Im hoping to get a lot of work done on it this weekend and maybe get it out the door
Posted: July 10 2002 at 21:33 | IP Logged Quote TonyNo
Cool!
Tony
didi
Posted: July 12 2002 at 09:34 | IP Logged Quote didi
If you decode an old keyboard, you'll have 101 digital inputs at once, since PowerHome reacts immediately to keypresses. It's by far the cheapest solution to your inputproblem. Of course you'll have to place a relay between the keyboard input and your doorbelcircuit.
Ciao.
Back to Top View didi's Profile Search for other posts by didi Visit didi's Homepage
Posted: July 12 2002 at 20:24 | IP Logged Quote TonyNo
Interesting idea, Didi. I'll have to consider that one.
Tony
Posted: August 03 2002 at 19:01 | IP Logged Quote TonyNo
I forgot about the associated delays and hacked a Mini Controller into an 8-channel PowerFlash device. At least now I have 7 more contact inputs I can put to use!
Tony
