Lazyman Groupie
| Posted: February 08 2006 at 22:11 | IP Logged
Just got my 2814UB Smarthome Manager Essential, Timer USB. Does this work with PowerHome? I got to the setup controller page. What am I supposed to select?
| Posted: February 09 2006 at 00:13 | IP Logged
Lazyman,
The latest beta version of PowerHome will support this device. You'll have to download from this link here (http://www.power-home.com/download/ph10345setup.exe) as the download page is not updated yet. Under Controllers, you'll choose the "Insteon DM" controller.
Since this is an Insteon device, be sure and read the phinsteon.rtf file in the PowerHome directory for IMPORTANT Insteon information and PowerHome use.
To all others...the next beta of PowerHome will be available in a day or so. I lot of changes were being tested in the 1.03.4.5 version and the fixes will be available in this next version.
krommetje Super User
| Posted: February 09 2006 at 13:53 | IP Logged
can we update from the current version to the next beta or do we have to install 1.03.4.5 and then the next beta?
Peter
Lazyman Groupie
| Posted: February 10 2006 at 01:20 | IP Logged
The reference to the phinsteon.rtf file was great. I would have never looked to it. Well written and a good explaination.
However, I am still having a problem. When I type DM, nothing happens.
In detail, here is what is happening:
I get the error message "The XXX PLC is not responding. Commands will not be sent." I double clicked on the new icon in the tray which opened the Adaptive Service Anywhere pwrhome window. The data in the window was as follows:
Failed to initialize NT performance monitor data area
Sybase Adaptive Server Anywhere Database Engine Version 6.0.4.3799
This software contains confidential and trade secret information of
Sybase, Inc. Use, duplication or disclosure of the software and
documentation by the U.S. Government is subject to restrictions set forth
in a license agreement between the Government and Sybase, Inc. or other
written agreement specifying the Government's rights to use the software
and any applicable FAR provisions, for example, FAR 52.227-19.
Copyright 1989-2000 Sybase, Inc. All rights reserved.
All unpublished rights reserved.
Sybase, Inc. 6475 Christie Avenue, Emeryville, CA 94608, USA
8192K of memory used for caching
Using a maximum page size of 2048 bytes
Starting database "pwrhome" (c:\program files\powerhome\database\pwrhome.db) at Fri May 21 2004 22:10
Starting checkpoint of "pwrhome" (pwrhome.db) at Fri May 21 2004 22:10
Finished checkpoint of "pwrhome" (pwrhome.db) at Fri May 21 2004 22:10
Database "pwrhome" (pwrhome.db) started at Fri May 21 2004 22:10
Database server started at Fri May 21 2004 22:10
Trying to start NamedPipes link ...
NamedPipes link started successfully
Trying to start TDS (TCPIP) link ...
TDS (TCPIP) link started successfully
Now accepting requests
I left clicked in the window, but nothing happened. Any suggestions would be appreciated.
| Posted: February 10 2006 at 09:23 | IP Logged
Peter,
Yes, you'll be able to update from either 1.03.4.4 or 1.03.4.5 to 1.03.4.6.
With any luck though, the 1.03.4.6 may be out tonight.
| Posted: February 10 2006 at 09:28 | IP Logged
Lazyman,
Thats the wrong icon . What you've opened is the Adaptive Server Anywhere which is the database server for PowerHome. Everything you posted with it is fine so you can just minimize it back.
The Device Manager icon looks kind of like a yellow "T". Don't bother looking for it though because Im certain it's not loaded. This version did not properly register the SDM activex control.
However, it's a real easy fix. Shutdown PowerHome and navigate to the PowerHome directory (default c:\program files\powerhome). Beneath the PowerHome directory should be a SmartHome\Device Manager directory. Go to it and launch the file SDM3.exe. This is the SmartHome Device Manager. When you launch it, it will automatically register the activex control and update the registry (you'll also see the "T" in the tray). Now just relaunch PowerHome. You should be good to go. From now on when PowerHome launches, it will automatically launch the SDM for you.
Let me know how it goes,
Lazyman Groupie
| Posted: February 11 2006 at 21:12 | IP Logged
Fixed that problem thanks. Again the file phinsteon.rtf was GREAT. However, I still have some simple questions.
I just converted my house to Insteon with a few x-10 devices remaining. I have the 2814UB Smarthome Manager Essential, Timer USB.
1) From the forums, it appears Powerhome still does not support the CM15A (which will come later). Is that correct?
2) To control my x-10 devices (and my insteon devices), do I need to use the TM751 and CM17A, in addition to the Insteon 2814UB Smarthome Manager Essential, Timer USB?
I know there is a basic concept I am missing here.
| Posted: February 12 2006 at 22:30 | IP Logged
Lazyman,
1. Correct. PowerHome does not yet support the CM15A. I'll be working on it shortly.
2. You can use your Insteon controller to send X-10 commands. You no longer need to use the CM17A (unless you're trying to control the relay output of a TM751. That device ONLY responds to RF X10 commands). Or, you can just use both. Create a controller for the Insteon and another for the CM17A. You may still be using a palm pad or other RF transmitter so may still need the TM751.
When you create your controllers, they'll be assigned an ID. When you create X10 and Insteon devices, you'll need to tell it the ID of the controller that controls it.
Lazyman Groupie
| Posted: February 13 2006 at 14:27 | IP Logged
I am not sitting in front of Powerhome so I may get some terminology wrong.
Things are going pretty well. I installed the controller, auto discovered all the devices and two-way communication was confirmed for every device.
Now, with Powerhome, I started linking the devices. On the new links (using Insteon dimmers as controllers instead of the PowerLinc V2) I am getting a lot of “Not Found” Any suggestions?
I have 2 signal enhancers..
2nd Question: Can I use Powerhome to assign x-10 addresses to Insteons? How?
QuickCarl Groupie
| Posted: February 13 2006 at 17:04 | IP Logged
I jsut installed the PH software (1.03.4.6) and is seems to have trouble auto-discovering any of the new Icon Lamplinc or Icon Appliancelincs.
I noticed that they aren't listed in the drop down for the device types either.
| Posted: February 13 2006 at 22:44 | IP Logged
Lazyman,
Before you start creating links with PowerHome, be sure you give it enough time discover all of your existing links. If you start creating links before PowerHome has discovered everything, you'll end up overwriting your existing links.
After giving PowerHome sufficient time to discover everything, if you have "NOT FOUND" in some of your links, that means your devices have links that are not valid and are wasting space.
PowerHome can be used to "assign" the X-10 address. It cannot place the device in "linking" mode however and this must be done at the device. To assign an X-10 address, the procedure seems to be: press and hold the "on" button until the device goes into "link" mode. Then send the X10 address you wish to assign 3 times.
To have PowerHome send the X-10 address, you can use a formula or a macro. The easiest may be just a formula. To send K4 3 times using a controller ID of "X10-1", you can use the following formula:
| ph_x10("X10-1","K",4,0) + ph_x10("X10-1","K",4,0) + ph_x10("X10-1","K",4,0) |
. To execute this formula, open the "PowerHome Multi Editor" and press "Shift-F6" (PH Formula should appear in the title. Copy and paste the above formula. Execute the formula by select Edit->Execute Script from the menu.
Let me know how everything goes.
| Posted: February 13 2006 at 23:07 | IP Logged
Carl,
You are correct, I dont have the ICON Lamp and ICON Appliance modules defined within the PowerHome database.
I don't have either of these devices so I cant test what Im about to tell you either.
Adding the new devices to PowerHome is easy enough. You could type it manually or import the SQL below:
INSERT INTO insteontypes VALUES (
17,
'2856S3 - Icon Appliance Module',
'1',
'On',
'Off',
'Dimmed',
'Unknown',
0,
65535,
0,
8421504,
0,
15793151,
0,
12639424,
NULL,
NULL,
NULL,
NULL,
1);
18,
'2856D2 - Icon Lamp Dimmer',
'1D',
'On',
'Off',
'Dimmed',
'Unknown',
0,
65535,
0,
8421504,
0,
15793151,
0,
12639424,
NULL,
NULL,
NULL,
NULL,
1);
To import the above SQL, open the PowerHome multi editor and press shift-F5 (SQL should appear in the title). Copy and paste the above SQL and then select Edit->Execute Script from the menu (Deja-vu). This will work if you have not made any changes to your Insteontypes table.
That should give you the ICON lamp and appliance module types. Give that a try and see if they are recognized now.
Let me know,
QuickCarl Groupie
| Posted: February 14 2006 at 10:08 | IP Logged
Thanks for makeing the sript entries to SQL for me... but I get an error.
Invalid Direct SQL Code -131
SQLSTATE = 37000
[Sybase][ODBC Driver][Adaptive Server Anywhere]Syntax error or access violation: near '[' in [[]code] ...
QuickCarl Groupie
| Posted: February 14 2006 at 10:13 | IP Logged
Sorry, my goof, didn't realize I needed to remove the
The entries worked great and are now part of th SQL DB.
Thanks so much for the help. -Carl
| Posted: February 14 2006 at 15:30 | IP Logged
Carl,
No problem. Keep me posted if you have problems or questions.
