         MrGibbage Super User
           | Posted: January 26 2014 at 08:47 | IP Logged
I have been using a 2414U for several years, and I think it is working fine. I occasionally have
 lights that don't go on or off with certain scenes, but other than that, it seems to be working
 fine. I see that this controller is now discontinued with the recommended replacement the 2413 USB
 and serial. (I think it is funny because years ago I had a PLC that was a serial device and they
 were discontinued for the newer USB. And now we are back to serial again. Truth be told, I prefer
 the serial anyway.)
 So, my question for the team here, is which controller should I be using now? I see a lot of folks
 using the ISYs, and those are crazy expensive. And it seems to me that if we are using powerhome
 (that is why we are here, right), then we really don't need something like the ISY.
 I am just trying to get the thoughts on which controller is the right one to use now, keeping future
 use and compatibility in mind.
  __________________ Skip
           | Posted: January 26 2014 at 14:23 | IP Logged
The 2414 PLC does not support Extended commands.  Devices
 such as Motion Sensors, TriggerLincs, just about all the
 battery devices along with just about any device now being
 delivered from Smarthome is I2CS which requires Extended
 commands for link management.
           | Posted: January 26 2014 at 15:59 | IP Logged
If I do upgrade to the 2413, does PH support both the USB and Serial versions? I think I would prefer to
 get the serial one if at all possible.
           | Posted: January 26 2014 at 16:07 | IP Logged
It does not matter from PH perspective.   Both are
 accessed through a serial port number.
           | Posted: January 26 2014 at 18:08 | IP Logged
Historically, the USB versions were a bit wonky. Not sure if they fixed that.
           | Posted: January 26 2014 at 20:19 | IP Logged
I second that. I have the USB and it is a pain in the neck if not lower.
           | Posted: January 26 2014 at 22:15 | IP Logged
I would definitely get the serial version if its an option.  The problem with the USB version is that the computer is usually on a UPS but the PLM is plugged directly in the wall.  The USB versions get wonky (at least they used to) when they lose power but the USB stays powered on by the computer.  Serial versions do not have this issue.
           | Posted: January 27 2014 at 19:21 | IP Logged
Interesting. My server has no UPS and it was wonky anyway. :D
           | Posted: January 27 2014 at 20:04 | IP Logged
So back to the original question does that mean the serial PLM is the best Insteon controller? Like in reliability.
           | Posted: January 28 2014 at 14:02 | IP Logged
In my opinion...yes  .
         Jaaay Newbie
           | Posted: January 29 2014 at 00:25 | IP Logged
I agree the serial PLM is rock solid (best). But I would
 also look at the networked hub version for the future. I
 really like the hub now that I got past the wonky virtual
 port issue.  I think the response time is better also,
 but that part could all be in my head. I have not really
 come across anything the hub can not handle that the
 serial PLM can.  (I don't use the hub for anything other
 than a PH insteon controller.) When I first started a
 while back I had a USB controller, but had to switch to
 serial because it was not reliable!! This is how I rank
 them base on my experience with them.
 1st serial (best)
 2nd network hub (being put to the test as we speak)
 3rd USB controllers
 Not to be confused with the (Insteon Portable USB adapter
 (2448A7) that Dave likes.)
