Subject Topic: How to get Insteon ID and Description Post ReplyPost New Topic
smarty
Posted: December 16 2011 at 15:36 | IP Logged Quote smarty
If any of my Insteon devices have a communications failure, I have a trigger set up that fires the following macro. This macro sends a text mesage to my phone. Macro is:
ph_sendsmtpemail("{EMAIL SERVER}",25,"{EMAIL ADDRESS-2}","{EMAIL TXT ADDRESS-1}","[TEMP1]","[TEMP10]")
Variable [TEMP1] will say "INSTEON COMM FAIL", and variable [TEMP10] will the the insteon address of the failed device (ie 19.47.B9).
Does any know how I could find insteon "ID" and "Description" corresponding to the insteon address?
I want my text message to tell me it was "bathroom lts" "load bearing north switch" at address "19.47.B9".
Edited by smarty - December 16 2011 at 15:37
JaredM
Posted: December 18 2011 at 01:43 | IP Logged Quote JaredM
I'd try querying the database directly. Since you said [TEMP10] has the Insteon address, this will get you the device's ID:
ph_sql(0,"select id from insteondevices where Address='[TEMP10]'")
...and this will get you its description:
ph_sql(0,"select key_desc from insteondevices where Address='[TEMP10]'")
Back to Top View JaredM's Profile Search for other posts by JaredM
smarty
Posted: December 18 2011 at 17:20 | IP Logged Quote smarty
Works like a champ....many thanks!
