Subject Topic: button to switch to tabs? Post ReplyPost New Topic
PhilC
Posted: March 21 2004 at 15:07 | IP Logged Quote PhilC
Hi,
does anyone know if it is possible to have a button on the control center that can switch to a different tab?
As an example, my main tab that has control for most of my devices is full up, so I want to add a button that simulates pressing the mouse on say the DVD control tab. The reason I want to do this is that my system is a touch screen and I want nice large buttons.
Many thanks
Phil
Back to Top View PhilC's Profile Search for other posts by PhilC
SteveA
Posted: March 21 2004 at 15:46 | IP Logged Quote SteveA
Phil,
You can use the formula ph_setcctab from a macro to set the tab, ph_getcctab will return the value of the current tab. I set up two buttons to scroll back and forth through the tabs by reading the current value and adding to or subtracting from it. By putting a min-max value in the macro you can allow the scrolling to wrap around.
Exp:
Pressing a button named -> calls a macro which adds 1 to the value in ph_getcctab. If the value is less than or equal to a global variable I named maxtabs I pass the value to the ph_setcctab formula, if not I send a 1 which takes me back to tab 1.
Pressing a button named <- calls a macro which subtracts 1 from the value in ph_getcctab. If the value is greater than or equal to one I pass it to ph_setcctab, otherwise I send the value of my maxtabs global which jumps to the highest tab number.
Good luck..
SA
SteveA
Back to Top View SteveA's Profile Search for other posts by SteveA Visit SteveA's Homepage
PhilC
Posted: March 21 2004 at 15:59 | IP Logged Quote PhilC
Thanks Steve, I can understand your method here, will give it a go later.
Phil
