Subject Topic: PH Lockup Post ReplyPost New Topic
BeachBum
Posted: December 19 2010 at 21:57 | IP Logged Quote BeachBum
Anyone got any idea why ph_copyfile to a mapped drive on another system would totally lockup PH to the point that the only way to recover is to power off then on? When I verify it always works and most of the time it will on the fly. But occasionally it will lock up in real time. It almost sounds like a Windows problem. Famous last words.. “Nothing has changed other than Windows updates”. PH is on Vista and the mapped drive is on XP. This has failed in various macros I use. It worked for a long time, year or two, without any problem whether it completed or not and now it intermittently takes me down.
Pete - X10 Oldie
BeachBum
Posted: December 26 2010 at 20:18 | IP Logged Quote BeachBum
Since nobody has seen this I have since uninstalled PH and reinstalled in its own directory. That being C:\Program\Powerhome\. It seems to have cured the problem but now I can’t get CallerId to trigger. I change the plugin to reflect the correct path and reregistered ph_cid.ocx. Any thoughts???
Pete - X10 Oldie
