Subject Topic: CM11A Woes Post ReplyPost New Topic
mustangcoupe
Posted: February 28 2004 at 07:58 | IP Logged Quote mustangcoupe
I am having problems with my CM11A. I read somewhere that they die often.  Does anyone know if this is true?  What is everone else using maybe I will consider switching to a better unit.
Todd Hannemann
HA newbie
   PowerHome - UPB - ELK
Posted: February 28 2004 at 11:46 | IP Logged Quote TonyNo
I have had the same CM11A for a few years now, with no problems yet. I'm keeping an eye on it, though...
mustangcoupe
Posted: February 28 2004 at 13:36 | IP Logged Quote mustangcoupe
I bought it in December... I had a problem in January and It went away after resettign the unti (unplugging and removing batteries...) and now it just dosnt seem to work, PowerHome tells me there is an error if I unplug it and try to run a command.  But with it plugged in and my RF receiver module TM??? plugged in the same outlet it dosn't  change state (ON/OFF) BUT it does with my keychain remote!
Todd Hannemann
HA newbie
Posted: February 28 2004 at 15:39 | IP Logged Quote TonyNo
Hmm. Sounds like it's dead. Is there a 90-day warranty? The cheapest way I know of to get another one is to buy a starter kit for $50. You could try e-bay, too.
There was recently some discussion here about using an Ocelot that you may want to look into.
mustangcoupe
Posted: February 28 2004 at 17:26 | IP Logged Quote mustangcoupe
I got this one off EBAY... Great price   I have to contact the seller agian. He is an authorized X10 dealer.
Todd Hannemann
HA newbie
Posted: February 28 2004 at 19:58 | IP Logged Quote dhoward
Wait wait !!
This is an easy one, nothings wrongs.  You're talking about your TM751 RF transceiver with built in appliance module.  This is a well documented problem.  The built in appliance module CAN ONLY be controlled via RF.  It does not respond to powerline commands (the one sent from your CM11A).  So Im guessing that nothing is wrong with either unit.  You can read a little about this problem here: http://www.geocities.com/ido_bartana/modifying_remote_control_transce.htm#Differences between RR501 and TM751
mustangcoupe
Posted: February 28 2004 at 22:44 | IP Logged Quote mustangcoupe
<------- Stupid newbie......
Yes it is fine now... But it was offered to be replaced from the guy where I bought it. I now have to write him and explain.....
Todd Hannemann
HA newbie
