Subject Topic: Infinite Loop Detected On Macro Post ReplyPost New Topic
patrickm
Posted: September 21 2010 at 11:09 | IP Logged Quote patrickm
Hello,
This morning I took a look at my event log and I had a couple of Infinite Loop Detected errors. This is quite puzzling since the macros have not been changed for a couple of years and run every night. I looked through the event log and noticed numerous web access entries from a local subnet IP address earlier. This was even more concerning since I do not use the web interface.
I tried deleting the event log and reinitializing. The database was still around 50M is size. I then tried to use the PHUPG.EXE to rebuild the database but it threw a bunch of errors when it ran.
I am getting the impression that the database is probably very messed up.
Any ideas?
-Patrick
grif091
Posted: September 21 2010 at 12:01 | IP Logged Quote grif091
Use the ph_trimeventlog function to logically reduce the size of the log. Then run the update utility to reduce the physical size.
Lee G
patrickm
Posted: September 22 2010 at 00:47 | IP Logged Quote patrickm
Thanks Lee I will try that.
Posted: September 29 2010 at 12:03 | IP Logged Quote dhoward
Patrick,
Let me know how you've made out. You definitely want to get your database down to 10MB or less. The PHUPG utility should work so just need to know what specific problems you're having.
Infinite loops may not actually be infinite. These settings are controlled by a couple of parameters in the PowerHome Explorer under PowerHome|Setup|Script. You'll see a "Maximum number of Recursive Calls" and a "Macro Jump Limit". MJL is a value that incremented everytime a jump is called within a macro. I typically set this to 0 (unlimited) since I may be jumping within a loop. You may have this value set to something else and if you exceed that number, you'll get an error. MNORC controls how many times a macro can be called. The default value is 30 and may just be low for your particular application. Its intended to catch situation where Macro A may call Macro B which calls Macro C which then calls Macro A type of situations. Its a global value and everytime a macro is called, it gets incremented. Everytime a macro terminates, its decremented. It is not on a per macro basis. So in the above situation, once Macro C is called, this value would be 3. Depending upon your programming style, you may want to increase this value.
patrickm
Posted: September 29 2010 at 13:54 | IP Logged Quote patrickm
Things are not "normal" yet. The database size is 3M now but reinitializing takes a very long time (>1 min). Triggers are very quick one minute and very slow the next.
I have a question about the Powerhome status window. There is a sequence number for the waiting macros. Should that number continually increase?
I have a few macros that I use for updating keypads and some data log files and they use a wait followed by a jump to the beginning of the macro. I do this rather than use a timed event to try to keep the event log from filling up with numerous macro calls. If I could filter specific events and macro calls from being entered into the log I would just use a recurring timed event.
How would you do this?
Thanks for your help.
Patrick
