doctorjerry Groupie
Online Status: Offline Posts: 57
Posted: March 13 2009 at 16:38 | IP Logged
All of a sudden none of my triggers will function. Some are initiated by X10 signals, some Insteon. Macros work fine. Is there some global setting that may have changed?
Jerome
__________________ Jerome
Posted: March 13 2009 at 18:56 | IP Logged
Make sure they all are enabled not checked DISABLED. If they aren’t then reload PH and see if that fixes it.
doctorjerry Groupie
Posted: March 13 2009 at 21:35 | IP Logged
Thanks for the quick reply. I forgot that I had rearranged the computer setup and the problem was the powerline filter that I did not replace. Absolutely necessary on the computer end. Problem solved.
Posted: March 13 2009 at 21:45 | IP Logged
Filter does make a big difference. Glad to see you’re up and running again…
