jeffw_00 Super User
Posted: November 02 2008 at 09:40 | IP Logged
Hi - i searched the forum, but all posts were for older versions of PH. I'm running the latest PH1. I notice that today the sunrise/sunset times are still calculated based on DST. How do I get it to realize we're no longer in DST and recalc? (I have DST checked under Setup->Sun).
Edited by jeffw_00 - November 02 2008 at 09:40
Posted: November 02 2008 at 10:11 | IP Logged
My V2 calculated Timed Events correctly but I can’t speak for V1 except they worked correctly last spring. Dumb question… Your system time is correct??
jeffw_00 Super User
Posted: November 02 2008 at 11:37 | IP Logged
of course, as is the time in PH
jbbtex Senior Member
Posted: November 02 2008 at 15:14 | IP Logged
My sunrise/sunset timed events calculate correctly too. However, I have a timed event that reinitializes PH each morning at 1am. Left over from when I was having SDM problems. I'm running PH2.
If your still having this issue, you may trying a reinit.
Edited by jbbtex - November 02 2008 at 15:18
__________________ Brady
jeffw_00 Super User
Posted: November 02 2008 at 15:24 | IP Logged
I tried a re-init, and exiting and restarting. I thought maybe today's events were calculated yesterday and that was the problem, so I tried entering a new event, and it calculated the same way (it just thinks sundown is around 6pm when I believe today it will be closer to 5pm). I have my city/state set properly, and I don't think I had this problem before (been using PH since summer 2007)
really weird - how do I fix??
thanks
Posted: November 02 2008 at 16:42 | IP Logged
First check to make sure that you have DST selected in PH Setup.
If so, then this may explain it. Though I vaguely remember there being a fix last February.
jeffw_00 Super User
Posted: November 02 2008 at 17:45 | IP Logged
Thank you jbbtex - that was a very helpful post, except...
-see my initial post. DST -is- selected
-the post you refer to is for a much older version of PH (see my initial post, I had already searched the forum)
8-}
I appreciate everyone weighing in, but my fear is that if this thread gets too long the people who know the answer will think I'm already taken care of! 8-}
thanks
jeffw_00 Super User
Posted: November 03 2008 at 20:49 | IP Logged
never mind.
It got better 8-}
I guess i had to wait a day or so for it to get right...
Powerhome. It rocks 8-}
