mustangcoupe Super User
Posted: September 16 2008 at 19:34 | IP Logged
I am starting this thread so we can try to consolidate any comments to Dave here for V2. I would still post a message in the bug forum if it is a true bug.
HA newbie
PowerHome - UPB - ELK
Posted: September 16 2008 at 19:39 | IP Logged
It's the little things that can be cleaned up after beta during a maintenance releases that will make the program feel smoother...
my first comments are try to keep things in the same location between explorer sections.
ex. the disable function is the 2nd item in the timed events section but the 5th in the triggers section.
Also you use 2 different types of check boxes... some are true check boxes other are X's (for the same command disable being the one to come to mind.)
HA newbie
Posted: September 17 2008 at 18:01 | IP Logged
when I change the type of a timed event it deletes the ID name
HA newbie
Posted: September 18 2008 at 08:25 | IP Logged
Colors in the status window may need to be tweaked I believe system errors, web access and system messages are red, now UPB items are also red...
edit: maybe I should say log not status window
Edited by mustangcoupe - September 18 2008 at 08:25
HA newbie
Posted: September 18 2008 at 15:30 | IP Logged
Appreciate this thread. This will help me to correct the minor issues.
Fixed the checkboxes so that they are consistent look and feel. Moved the triggers "Disabled" so it matches the others and is right after the Description (3rd column). Timed Events will still stay the second column since it doesnt have a description field.
In Timed Events, the "ID/Sendkeys" field is cleared if you change the type...this has always worked this way. It also does it on the Macro lines and triggers so that when changing from a free form field to dropdown field (such as formula to a macro) it keeps errant data from being entered. I can undo this and just allow the data to stay (I find this annoying to particularly in the macro screen where sometimes the type change is compatible).
Dohh!! I definately forgot to update this. It's fixed now. In the meantime, you should be able to correct it by running these statements in the Multi-Editor as SQL mode:
update dropdowns set ddnumval = 65280,ddcharval = '#00ff00' where ddtype = 1001 and ddsort = 34
update dropdowns set ddnumval = 16776960,ddcharval = '#00ffff' where ddtype = 1001 and ddsort = 35 |
Definately keep'em coming
jbbtex Senior Member
Posted: September 19 2008 at 09:28 | IP Logged
Upgrade instructions - You may want to add.
If PH is not installed in the default directory(c:\programfile\powerhome\) you will get the message "An error occurred while creating the script server: -3"
To correct you need to change the path in this entry
[HKEY_CLASSES_ROOT\CLSID\{BCA03350-93FF-420E-8206-7480BC20B767}\PowerBuilder\LibraryList]
@="c:\\program files\\powerhome\\phscr.pbd" |
in the file phscr.reg located in the powerhome directory.
Then right-click the file and select "Merge."
__________________ Brady
Posted: September 20 2008 at 10:45 | IP Logged
From changes.txt...
Quote:
Expanded PowerHome Status page to show all pending timed events in order rather than just the single next one. |
I don't see any timed events.
nadler Super User
Posted: September 20 2008 at 10:57 | IP Logged
Expand the box. They start on the second line. You can
save the new box size by right clicking and clicking on
save.
Posted: September 20 2008 at 17:06 | IP Logged
Ah. In the System Status window. Thanks.
Heh. That window does interesting things when you use a scroll wheel!
Edited by TonyNo - September 20 2008 at 17:08
Posted: September 21 2008 at 08:46 | IP Logged
Still having Timed Event issues. I now see that the macro is being called, but the macro commands don't get executed.
Posted: September 21 2008 at 09:44 | IP Logged
Let me see if I’ve got this right. The event is firing and calls a macro that doesn’t execute. Is the macro being called from the Boolean field as a Raw Formula or from the ID as a Macro?
Posted: September 21 2008 at 11:37 | IP Logged
ID as a Macro.
The macro is simply two Insteon commands, in two different flavors (to see if that mattered)...
10 Insteon Porch Light Off
20 Device Control INSTEON+WALK LIGHTS+OFF
Posted: September 21 2008 at 13:21 | IP Logged
I don’t know Tony.. That’s no different than what I’m doing. I know you checked the Boolean for 1 which on mine is no longer called Boolean.
Posted: September 21 2008 at 17:35 | IP Logged
Strange one, indeed. The macro is being called, per the log, unless there is some condition where the macro doesn't really execute.
Posted: September 21 2008 at 17:40 | IP Logged
But you can execute the macro from the pull down right??
Posted: September 21 2008 at 20:15 | IP Logged
Yup.
Posted: September 21 2008 at 20:30 | IP Logged
The Stars and Moon are not lined up correctly….
Posted: September 24 2008 at 20:36 | IP Logged
Shoot me an email. I'd like to schedule a VNC session so I can do some remote troubleshooting.
Posted: September 24 2008 at 22:47 | IP Logged
Email sent!
Funny, the Timed Event worked tonight...
