Posted: August 30 2008 at 11:18 | IP Logged
I thought one could "push" an X10 address to an Insteon device using PH, but have been unable to do so (I think).
Using the Insteon Explorer>Devices Tab I set the Desired X10 address and did multiple Refresh/Saves as well as Re-initializations but the Actual X10 Address (at the cursor) never changes from blank.
What am I missing here?
Posted: August 30 2008 at 12:00 | IP Logged
There is a "Write Level/Ramp/X10" option at the top of the Insteon Explorer window. See the following topic...
http://www.power-home.com/forum/forum_post s.asp?TID=1189&KW=x10+address
Edited by grif091 - August 30 2008 at 12:05
Posted: August 30 2008 at 14:11 | IP Logged
Ahhh yah! Forgot about that. Turned it off when I cleaned out all my X10 devices (except I forgot I had one in the garage) and forgot all about turning it back on again!
