Subject Topic: Can I choose the sound device for PH? Post ReplyPost New Topic
jostim
Posted: January 03 2008 at 20:09 | IP Logged Quote jostim
My computer has two sound cards and a USB headset. One of the sound cards is set in 'Control Panel' as the default device. The other is used by Winamp feeding the stereo system.
The PowerHome sounds (used for alarm system messages, door gong and such) are played through the headset for some reason. Can this be changed?
thanks
- jos
- jos
Back to Top View jostim's Profile Search for other posts by jostim
Posted: January 15 2008 at 16:21 | IP Logged Quote dhoward
Jos,
Not currently. PowerHome uses the default sound device for all of it's sound functions.
However, I'll do some research and see if this is something that I can add in a future release.
jostim
Posted: January 19 2008 at 09:19 | IP Logged Quote jostim
sorry,
I didn't properly explain.
Here's my problem. PowerHome isn't using the default device. The default device is the build-in sound card, but PowerHome uses the USB headset.
I tried changing the default device to the USB headset, restarting PowerHome and testing the sound output (still Headset).
Changing the default device back to the build-in sound card, and restarting PowerHome didn't help either.
PowerHome always uses the headset as output device.
suggestions?
- jos
Edited by jostim - January 19 2008 at 10:34
- jos
jbbtex
Posted: January 19 2008 at 20:14 | IP Logged Quote jbbtex
If you're talking about TTS, you can assign a device in windows control panel.
Brady
jostim
Posted: January 23 2008 at 01:57 | IP Logged Quote jostim
Brady,
thanks for your suggestion.
I am using ph_playsound to play a sound, so TTS shouldn't make a difference. It was set to the build-in sound card anyway.
I'm afraid that's not it.
- jos
- jos
BeachBum
Posted: January 23 2008 at 08:45 | IP Logged Quote BeachBum
Don’t know if this has anything to do with it but what app is the default for playing WAV files? And what does that app use for the sound device?
Pete - X10 Oldie
jostim
Posted: January 24 2008 at 19:38 | IP Logged Quote jostim
The default app for WAV files is Winamp and it uses one of the sound cards as the sound device. (That is how I play music: PowerHome controls Winamp, playing through a Sounblaster Audigy sound card)
Good thought, but that's not the problem I think.
thanks
- jos
- jos
