Subject Topic: Help function Post ReplyPost New Topic
jostim
Posted: January 02 2008 at 22:37 | IP Logged Quote jostim
I made the change to run PowerHome as a service. After I made this change the help function doesn't work anymore. When I click the question mark (or 'help' -> 'contents', or ALT+F12) my pointer changes briefly to an hour glass, but nothing else happens.
I installed PH on a second machine running it as a program, so I can use 'help'.
Any idea what might be wrong?
- jos
- jos
Back to Top View jostim's Profile Search for other posts by jostim
Posted: January 02 2008 at 23:01 | IP Logged Quote dhoward
Jos,
Ive noticed this on a couple of machines as well and need to track it down. The only thing that I can think of at the moment is that we're running in to the same old problem of PowerHome as a service running under a system user account that does not have the HTML help activex control registered.
As a quick fix, try the following. Have PowerHome running as a service. This means that PowerHome will be running as a special system account that is used just for services. Open the multi-editor and set it to PH Formula mode (shift-F6). Type in the following command:
ph_run('regsvr32.exe "c:\windows\system32\hhctrl.ocx"')
Pay attention to the use of single and double quotes. Execute this function in the multi-editor. You should get a window saying that the DLL Register Server succeeded. This should tell the special system account about the HTML Help activeX control. Try launching the help and see if it now works. If so, I'll build this into the next beta.
jostim
Posted: January 03 2008 at 19:44 | IP Logged Quote jostim
thanks for the quick response. I tried your suggestion. I got the message:
"DllRegisterServer in c:\windows\system32\hhctrl.ocx succeeded"
Unfortunately the help function still doesn't work. No change.
- jos
- jos
Posted: January 15 2008 at 16:24 | IP Logged Quote dhoward
Jos,
I tried this as well and also had no luck . I'll do some more research and see what I can do to make sure that the help system can be launched from PowerHome run as a service.
ficklma1
Posted: January 15 2008 at 16:46 | IP Logged Quote ficklma1
Something else I've noticed when running PH as service I can't get the PH GUI to open up, since it's technically already running as a service. I of course Kill the service and start up PH "normally", then make any changes, go to the device control screen, turn light on/off, etc.
Is there are way to have the PH service show the GUI?
Mark
Back to Top View ficklma1's Profile Search for other posts by ficklma1
