Subject Topic: Insteon Device Chg Variables Post ReplyPost New Topic
AllanMar
Posted: November 10 2007 at 15:07 | IP Logged Quote AllanMar
I found a post on here that detailed the TEMP variables for this trigger, but does anyone know the LOCAL variables it also populates? and what they are?
Back to Top View AllanMar's Profile Search for other posts by AllanMar
jbbtex
Posted: November 10 2007 at 21:10 | IP Logged Quote jbbtex
AllanMar,
I wrote a macro to display all the LOCAL VARS then triggered on an INSTEON DEVICE CHG. 1 through 8 returned NULL and 9 & 10 returned 0 (zero).
HTH
Brady
Posted: November 11 2007 at 13:45 | IP Logged Quote dhoward
Allan,
The "Insteon Device Chg" trigger populates [LOCAL] variables 7,8,9, and 10. [LOCAL9] contains the previous level value, [LOCAL10] contains the new level value. Since the Insteon Device Chg trigger can fire without the level actually changing, placing [LOCAL9] <> [LOCAL10] in the Boolean field of the trigger is a good way to have the trigger *only* fire when the level actually changes.
The [LOCAL7] var contains the ID of the Insteon device that is actually changing. [LOCAL8] contains the Insteon address of the device that is changing.
cmidgley
Posted: November 24 2007 at 17:50 | IP Logged Quote cmidgley
I've been searching and searching for the post that describes the other TEMP variables used in the Insteon Device Chg trigger, but no luck. Anybody have that link? I did log all the TEMP variables, and while some are obvious, some are not...
- Chris
EDIT: Found it here
Edited by cmidgley - November 24 2007 at 17:54
Back to Top View cmidgley's Profile Search for other posts by cmidgley
