        | NorthernAl Groupie
          I've been using PH for a while so it seems crazy to ask these simple questions but not knowing the answers bugs me!
           | Posted: March 17 2007 at 12:40 | IP Logged |   |
 - where is the log stored? in DB or disk file? If disk can it be deleted off disk?
 - I ask because due to a clock problem on my pc I ended up with events in the future in my log. Hard to get rid of them (even with log trim command)
 - is the only way to refresh the log window to close and reopen it?  A refresh button would be nice.
        | TonyNo Moderator Group
          The log is in the DB.
           | Posted: March 17 2007 at 14:41 | IP Logged |   |
 I view the log via the web. Seems quicker and has a refresh button.
          The log is in the database in two tables...eventlog and weblog.  You can get rid of events in the future with this SQL statement:
           | Posted: March 19 2007 at 17:14 | IP Logged |   |
 delete from eventlog where time_stamp > today()
 When the eventlog report is open (and active), F5 will refresh the data.
 Also, the PowerHome Status screen has a realtime eventlog window.  You can size this window to be the predominant window if you like and change a setting in the pwrhome.ini file ([PowerHome Status] eventlogrows) to go from the default last 10 rows displayed to more if you like.
