         mdsmith Newbie
 Online Status: Offline Posts: 14
           | Posted: September 21 2021 at 10:58 | IP Logged
Using PH on Windows 10 pro, having problems with Insteon
 powerlinc V2 2414 USB where PH Message- "ISRESPONDING failed
 for PLC powerlinc V2". Has anybody had the same problem? If
 so, are there any solutions to this problem?
           | Posted: September 21 2021 at 15:20 | IP Logged
1) Has the controller been setup in the controller section?
 Next,
 2) Have you set up the Insteon PLC/PLM in the Insteon  "Setup" area?  "Clear" the PLC/PLM database and then "Add Full".
 Insteon has had a fair number of early device failures (all types).  I have replaced easily over 50 devices over my years with Insteon.  Is it possible that youe PLC is dead?
  Edited by smarty - September 21 2021 at 15:21
         mdsmith Newbie
           | Posted: September 21 2021 at 16:23 | IP Logged
Thank you for your message. Yes the controller is setup in
 Controller. I tried your suggestion but it still fails. I
 know the unit is working ok, I have been using it on my
 Windows 7 PC and it works fine. If you think of any other
 suggestion would be greatly appreciated...
 Thank you...Michael
  Edited by mdsmith - September 21 2021 at 16:26
