MrGibbage Super User
Posted: November 28 2018 at 18:55 | IP Logged
Not a PH question, but probably relates to a lot of us here.
I am trying to get my Insteon Hub into my Harmony Elite Hub as a device, but so far no luck. I have the Insteon app on my android phone
and it works fine with the Insteon Hub. I have one network in my house and everything (wifi access points and wired connections) goes
through one switch. No proxies.
Things I have tried:
Tried adding the Insteon hub using using the Harmony app on my phone with the "find wifi devices" and with the Home Automation->Insteon
Hub. I enter the password on the insteon login page, get a message that I was authenticated and that I should redirect back to harmony
within 15 seconds. Never redirects and when you click the link to manually redirect, it says no devices found.
I also tried using the Harmony desktop app. Similar results.
I also tried creating a new Insteon account, just in case.
I master reset the hub (fortunately I only have a few devices in there so far)
My hub is the 2245-222 model
What else can I try?
Skip
__________________ Skip
