        | MrGibbage Super User
          I finally got me an ISY994 controller. I have been playing with it outside of PH, using just
           | Posted: September 02 2018 at 07:18 | IP Logged |   |
 |  the ISY Launcher and admin console to make some links and scenes. I want to add it to PH to use
 as my primary controller and move away from the USB PLM that I am currently using. I went to
 add it as a new controller, and I don't see ISY as an option. And the only options for PLM
 require a COM port-no place for an IP address. So, how do I add the ISY controller? Also, is
 there a way for PH to look into the ISY & PLM and grab all of the links and scenes in there
 already and pull them into the PH database?
 Skip
        | johnsmith Newbie
           | Posted: September 17 2018 at 14:25 | IP Logged |   |
 using just
 |  |  |  As long as you are not trying to control the same
 devices with both controllers, you should be fine.  A
 device should only be linked with one HA controller.
 If moving a device from one controller to the other, a
 factory reset should be done on the device after
 removing from one controller and before adding to the
 other.
