         Francorosso Newbie
           | Posted: September 30 2017 at 12:18 | IP Logged
Hi everyone,
 I have been using Houselinc 2 with a powerlinc USB
 modem for years.  Somehow I was convinced to buy a
 smarthub and use the HUB for Insteon software on my
 Windows PC and iPhone.  It was a total disaster.
 Nothing worked right and it took LITERALLY hours to
 try and program scenes which wouldn't work right
 anyway.  I'll admit many of my switches and lamplincs
 are old, but why didn't they tell me they wouldn't
 work?
 In any event, I'm looking to an alternative to
 Houselinc which as I'm sure you know isn't supported
 and also has many issues which make it less than
 ideal.
 So, my questions:
 1. Can I use the PL USB modem with Powerhome?
 2. Can I use the Smarthub with PH?
 3. Is this software better than my old Houselinc?
 4. Any gotchas I need to know before I take the leap?
 Is it worth changing? etc....
 I have about maybe 30 devices, all insteon switches
 and lamplincs, ranging from 2 years old to maybe seven
 or 8 or more..
  __________________ Frank
           | Posted: September 30 2017 at 15:33 | IP Logged
1) Yes
 2) No
 3) Yes, but I use it for MUCH MORE than just Insteon.
 4) There is a decently steep learning curve for this software, but with that come much power and flexibility.  A decent portion of your older Insteon switches will likely fail soon... that is what most of mine (80+ devices) have done.
         Francorosso Newbie
           | Posted: October 02 2017 at 05:41 | IP Logged
 Yes, I have had switches failing recently.  One more
 question - the older switches seemed to work ok with
 Houselinc, but didn't work well with the SMarthub.  Does
 power-home play well with older Insteon switches?
 Frank
           | Posted: October 02 2017 at 13:11 | IP Logged
PowerHome plays well with both in my experience.
         Francorosso Newbie
           | Posted: October 03 2017 at 11:54 | IP Logged
