         nick7920 Senior Member
           | Posted: October 20 2016 at 18:36 | IP Logged
I had to replace my PLM and I was able to get most of
 the links. but insteon 2475S relay which is connected to
 outdoor motion light  has a problem.
 to create a link thru Insteon explorer
 link tab then under responders. I tried to drag and drop
 my PLM ,I see the clip board but nothing happens. but I
 was able to create as controller but not as responder.
           | Posted: October 20 2016 at 18:51 | IP Logged
solved :
 I still did not see any thing when I drag and Drop.
 couple of things I tried  - try to put that device
 into link mode under manual linking.
 went back to links and refresh the device and now
 see the PLM as a responder.
 also I did not see any created link under completed
 operation when that device was poll.
  Edited by nick7920 - October 20 2016 at 18:52
           | Posted: October 21 2016 at 08:39 | IP Logged
Not sure that I follow....could you articulate that a bit more....
