        | TonyNo Moderator Group
          I've started a new project to enable PH to get and respond to local weather alerts. The only problem I can see is that this uses polling, and sometimes warnings are issued only minutes before the event is to occur.
           | Posted: April 08 2006 at 09:56 | IP Logged |   |
 You need to create a new Global Variable called "CURWWA", and update your zone info in ph_geturl. Zone info is available here by drilling-down to your location (click on the correct XML button).
 wwa.sql
          Hmm. This will be tougher than it seemed. Multiple alerts will happen and need to be dealt with (i.e. a watch and a warning). In the XML file, each alert is in an <item> tag.
           | Posted: April 08 2006 at 19:33 | IP Logged |   |
 VB script seems to support XML parsing via a DOM that could handle this elegantly (like the current INI/profile file handling), but I'd like to try and keep this in PH.
 More later.
           | Posted: April 09 2006 at 20:34 | IP Logged |   |
 This looks really interesting.  Please keep us posted.  If you need any help on how to do something, just let me know.
          Holy schnikeys!
           | Posted: April 09 2006 at 23:40 | IP Logged |   |
 Here is what I thought would work...
| Code:
       | ph_setvar_a( 1, 3, 1) + ph_doloop( "ph_concatvar( 1, 2, ph_regexdiff( '<item>~255<title>', '</title>', '[LOCAL1]', ph_getvar_n( 1, 3)) + ', ') + ph_setvar_a( 1,  3, pos('[LOCAL1]', '<item>', [LOCAL3] + 1))", "[LOCAL3] <> 0") |  |  |
 But I just realized that I need to rework it to use ph_regex so I can put the position of the last found string in LOCAL3.
 That will have to wait until tomorrow!
          How would I code a regexdiff with plain regex command?
           | Posted: April 10 2006 at 22:07 | IP Logged |   |
           | Posted: April 11 2006 at 16:22 | IP Logged |   |
 Im thinking this:
| Code:
       | ph_rtnes(ph_regex("<item>~255<title>","[LOCAL1]",ph_getvar_n(1,3),0,4,5))) + ph_rtnes(ph_regex("</title>","[LOCAL1]",ph_getvar_n(1,4) + ph_getvar_n(1,5),0,6,7)) + ph_mid("[LOCAL1]",ph_getvar_n(1,4) + ph_getvar_n(1,5),ph_getvar_n(1,6) - ph_getvar_n(1,5) - ph_getvar_n(1,4)) + ph_rtne(ph_setvar_a(1,3,ph_getvar_n(1,6) + ph_getvar_n(1,7))) |  |  |
 [LOCAL3] should start at 1 and will be incremented with the new starting point with each successive search so that you can place it in a loop.
 What Im doing is a ph_regex looking for the first piece of code.  Im setting [LOCAL4] to the start and [LOCAL5] to the length.  Im using ph_rtnes so I get an empty string.  I then search for the end piece of code using the previous [LOCAL4] + [LOCAL5] as the starting point.  This start and length is placed in [LOCAL6] and [LOCAL7].  I could save some variables by reusing but didnt here for clarity sake.
 I then use a ph_mid function to extract the data between the two regex commands.  Last, I set [LOCAL3] to the end of the previous search so that it is set for the next search.
          Cool. I'll try this tonight!
           | Posted: April 11 2006 at 17:13 | IP Logged |   |
          OK, I found some typo's...
           | Posted: April 11 2006 at 21:48 | IP Logged |   |
| Code:
       | ph_rtnes(ph_regex("<item>~255<title>","[LOCAL1]",ph_getvar_n(1,3),0,4,5)) + ph_rtnes(ph_regex("</title>","[LOCAL1]",ph_getvar_n(1,4) + ph_getvar_n(1,5),0,6,7)) + mid("[LOCAL1]",ph_getvar_n(1,4) + ph_getvar_n(1,5),ph_getvar_n(1,6) - ph_getvar_n(1,5) - ph_getvar_n(1,4)) + ph_rtne(ph_setvar_a(1,3,ph_getvar_n(1,6) + ph_getvar_n(1,7))) |  |  |  More later!
          Update! The macro now grabs all alerts listed and puts them into the Global "CURWWA". I still need to have this trigger an announcement or do something more useful.
           | Posted: April 12 2006 at 22:24 | IP Logged |   |
 WWA2
          Heh. Caught my first watch tonight!
           | Posted: April 13 2006 at 21:58 | IP Logged |   |
        | mustangcoupe Super User
           | Posted: April 13 2006 at 22:13 | IP Logged |   |
 I was just playing with this macro, and wondered... How often is enough to run a macro?  I dont want to over work the PC(it is running windoz
 How often do you rin your macros, this one, the weather macro, ect...
 Todd Hannemann
 HA newbie
  PowerHome - UPB - ELK   |
          Great question. Figure out how often YOU want them to run, then offset the reference time of those that will hit at the same time. You don't want several to fire at once.
           | Posted: April 14 2006 at 07:35 | IP Logged |   |
 Macro, Freq, Ref Time
 email, 6, 00:18
 check ip, 15, 00:20
 ping, 15, 00:23
 wwa, 15, 00:26
 weather, 30, 00:45
 Edited by TonyNo - April 14 2006 at 07:36
          I now filter out all alerts except watches and warnings, and then do something with the info...
           | Posted: April 17 2006 at 23:50 | IP Logged |   |
 If home:
 - Announce new alert
 - Pop-up alert on all computers here (via YAC)
 If away:
 - Send a text message to my cell phone
           | Posted: April 19 2006 at 22:30 | IP Logged |   |
 What is YAC?
          YAC = Yet Another Caller id app
           | Posted: April 19 2006 at 23:09 | IP Logged |   |
 http://sunflowerhead.com/software/yac/
        | theowl Groupie
           | Posted: June 17 2006 at 15:36 | IP Logged |   |
 Does this macro grab the title of the alert, or title and description? I grabbed an alert today and got "Short Term Forecast - Vernon (Wisconsin)" and that was it.
 Here's the RSS it's reading from...
 <?xml version="1.0" encoding="UTF-8" ?>
 - <rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/">
 - <channel>
 <title>Wisconsin - (Vernon/WIZ053) - Current Watches, Warnings and Advisories for Wisconsin Issued by the National Weather Service</title>
 <link>http://www.weather.gov/alerts/wi.html</link&g t;
 <lastBuildDate>Sat, 17 Jun 2006 14:48:00 EDT</lastBuildDate>
 <ttl>4</ttl>
 <language>en-us</language>
 <managingEditor>robert.bunge@noaa.gov</managingEdit or>
 <webMaster>w-nws.webmaster@noaa.gov</webMaster>
 <description>Current Watches, Warnings and Advisories for Wisconsin (Vernon/WIZ053) Issued by the National Weather Service</description>
 - <image>
 <url>http://weather.gov/images/xml_logo.gif</url> ;
 <title>NOAA - National Weather Service</title>
 <link>http://weather.gov</link>
 </image>
 - <item>
 <title>Short Term Forecast - Vernon (Wisconsin)</title>
 <link>http://www.weather.gov/alerts/wi.html#WIZ053.ARX NOWARX.183400</link>
 <description>BLACK RIVER FALLS...LA CROSSE...<br>PRAIRIE DU CHIEN...SPARTA/TOMAH...VIROQUA...WINONA<br>134 PM CDT SAT JUN 17 2006<br><br>.NOW...<br>THROUGH 3 PM...LOOK FOR SOME SHOWERS AND PERHAPS A THUNDERSTORM TO<br>MOVE NORTH INTO THE AREA. MOST OF THE SHOWERS WILL BE EAST OF<br>PRAIRIE DU CHIEN AND LA CROSSE TO THE TOMAH AND BLACK RIVER FALLS<br>WISCONSIN AREAS. RAIN AMOUNTS THROUGH 3 PM WILL RANGE FROM A<br>TRACE...UP TO TWO TENTHS OF AN INCH WITH ANY THUNDERSTORMS. SHOWERS<br>AND THUNDERSTORMS ARE EXPECTED TO BECOME MORE WIDESPREAD AND<br>NUMEROUS THROUGH THE MID AND LATE AFTERNOON  HOURS.<br><br>$$<br><br>RRS<br> ;<a href=http://www.crh.noaa.gov/arx/>Issuing Weather Forecast Office Homepage</a></description>
 </item>
 </channel>
 </rss>
 I'm trying to figure out your macro code by code, but it's taking some time.
          It just grabs the title. The description was too long for my purposes. In the version I run, I filter out some of the titles (like short term forecasts).
           | Posted: June 17 2006 at 16:29 | IP Logged |   |
        | theowl Groupie
          Ahh, OK
           | Posted: June 18 2006 at 17:55 | IP Logged |   |
 I finally sat down and wrote out your code. Basically, your just seeking the <item>, then the <title>. Located the ending </title>...and grabbing information between. Seems so simple once I got to understand how it was working.
 Now to get it to grab the <description> tag as well since my PH system is 95% TTS........at least, for now
 Great Job!
        | brian2170 Newbie
          Hi guys, i have been away from my power home projects for a while, but after the tornadoes here in Virginia, I am interested in the weather alert macros. I copied the macro form Tony's post(thank you), I would like to know how to filter out all but the watches and warnings for my area.   Any help would be greatly appreciated, Thank you.
           | Posted: April 29 2008 at 17:34 | IP Logged |   |
 |  Brian
          That should be all you are getting.
           | Posted: April 29 2008 at 17:41 | IP Logged |   |
 Did you go to the link and find your location?
