        | phil13 Groupie
           | Posted: April 21 2005 at 11:25 | IP Logged |   |
 for simplify maintening, i would like to use default path in formula.
 For example, i've write :
 ph_runscript_3 ("..\vbscript\serena.vbs", "vbscript", 1, 2000, "cmd_ballon2", "off", 0, "0")
 rather than :
 ph_runscript_3 ("H:\Program Files\powerhome\vbscript\serena.vbs", "vbscript", 1, 2000, "cmd_ballon2", "off", 0, "0")
 But it seems to works sometime and don't work other time ... The reference path seems to change with time.
 What do i have to write ?
 Philippe
          Philippe,
           | Posted: April 21 2005 at 13:44 | IP Logged |   |
 Thats the problem that Peter was having.  Over the course of time (or some unknown event) the current path would change.
 One suggesting may be to use the ph_getphdir function.  Something like:
 ph_runscript_3(ph_getphdir() +  "\vbscript\serena.vbs","vbscript",1,2000,"cmd_ballon2","off" ,0,"0")
 The other thing perhaps would be to store the vbscript directory into a global variable and then use that:
 ph_runscript_3("{VBDIR}\serena.vbs","vbscript",1,2000,"cmd_b allon2","off",0,"0")
 where {VBDIR} = "H:\Program Files\powerhome\vbscript"
 Since the path is subject to change, I would always code the full path rather than rely on the relative path.
        | phil13 Groupie
          perfect dave .. as always
           | Posted: April 21 2005 at 14:00 | IP Logged |   |
 thanks
