| Posted: November 22 2014 at 19:56 | IP Logged
I'm using ph_sendsmtpemail, but, it's still hanging up when I send mail. Today, Outlook stuck right after sending an email, and, I came home to find a message box about compacting messages. Once I clicked through that, PH started running again. Interestingly, timed events seem to have still been processed during this time.
Any ideas?
| Posted: November 23 2014 at 21:46 | IP Logged
Not sure why this would be happening. The ph_sendsmtpemail function has no connection to Outlook at all (it uses a raw socket to connect to your SMTP server to send the email). The ph_sendemail function of course uses your default MAPI client which in your case would be Outlook. The ph_processemail function also uses the MAPI client if you're using that function.
Looking at your eventlog screenshot, you've got to be using the ph_sendemail function as the ph_sendsmtpemail??? functions do not make an eventlog entry.
| Posted: November 24 2014 at 07:04 | IP Logged
Holy cow. I just noticed that I had the SendSMPTPemail function in a Send Email block.
Sorry!
