        | onhiatus Senior Member
          So I've got my thermostat automated, and I've got a motion detector. What I'd like to happen is have the thermostat get turned up after 3 minutes of continuous occupency, and turned off after 10 minutes of continuous absence. Basically I want to implement a buffered occupency sensor.
           | Posted: February 11 2005 at 18:08 | IP Logged |   |
 I've worked out a way to do this, but it seems awkward and very tempermental. I'd like to know if someone has a more elegant way of doing it.
 First off, my motion sense is one of the x10 ones (it sends an A16 ON when movement is detected, and an A16 OFF after 1 minute of no movement)
 I don't have my actual macro sitting in front of me but here is the pseudo code:
 Triggers:
 Triger1 is on A16 ON, runs macro StartOccupied
 Triger2 is on A16 OFF, runs macro StartUnOccupied
 Globals:
 Occupied - The room is already marked occupied
 Running - One of the occupied macros is mid run
 rOn - An A16 ON has been recieved
 rOff - An A16 OFF has been recieved
 Macro: StartOccupied:
 - - if (Running)
 - - - - set rOn
 - - - - exit
 - - else
 - - - - if (occupied) exit
 - - - - set Running
 - - - - set rOn
 - - - - Clear rOff
 - - - - set timed event: in 3 minutes run CheckOccupied
 Macro: StartUnOccupied:
 - - if (Running)
 - - - - set rOff
 - - - - exit
 - - else
 - - - - if (Not occupied) exit
 - - - - set Running
 - - - - set rOff
 - - - - Clear rOn
 - - - - set timed event: in 10 min run CheckUnOccupied
 Macro: CheckOccupied
 - - if (not rOff) run SetOccupied
 - - clear rOn
 - - clear rOff
 - - clear Running
 Macro: CheckUnOccupied
 - - if (not rOn) run SetUnOccupied
 - - clear rOn
 - - clear rOff
 - - clear Running
 Macros SetOccupied and SetUnOccupied set a global variable as a flag for other macros and turn on / off the heat.
 Is there a simpler way to do this?
 Thanks, Tony
 Edited by onhiatus
           | Posted: February 14 2005 at 16:09 | IP Logged |   |
 Based upon your criteria, I would do it the following way.  It's psuedocode and may not be any more elegant than yours, but I submit it for further thought.
 Triggers:
 Globals:
 - - if (macro StartUnoccupied is waiting) then kill StartUnoccupied macro
 - - if (Occupied) then exit
 - - if (macro StartOccupied is waiting) then exit
 - - Wait 3 minutes
 - - Set Occupied
 - - Set Thermostat
 - - if (macro StartOccupied is waiting) then kill StartOccupied macro
 - - if (Not Occupied) then exit
 - - if (macro StartUnoccupied is waiting) then exit
 - - Wait 10 minutes
 - - Clear Occupied
 - - Setback Thermostat
 Ive just run it through my head and I think it meets your requirements.
 Let me know,
          You can kill a macro??? That does make life a lot easier - and not just for this macro. I'll need to dig up the documentation on that...
           | Posted: February 14 2005 at 17:35 | IP Logged |   |
 What happens when a macro is waiting - this doesn't hang the entire macro queue? How are macros processed?
 Thanks, Tony
        | TonyNo Moderator Group
          Yup. Makes a lot of things easier.
           | Posted: February 14 2005 at 19:40 | IP Logged |   |
 From the docs...
 This command will suspend execution of the current macro but is different from the Delay command in that it will NOT stop the execution queue from processing waiting commands. The macro is actually terminated but the System Variables [LOCAL1] thru [MACRO10] and [TEMP1] thru [TEMP10] are stored and a timer started. When the timer is up, the macro is reinserted into the execution queue and will resume processing at the statement following the Wait command. Enter a formula that evaluates to the number of seconds you would like to wait in the Send Keys field.
 Remember that the Delay command works in milliseconds, the Wait command works in seconds.
          Just in case anyone was wondering, using ph_killmacrowait (or something like that) worked like a charm. Thanks for the help!
           | Posted: February 16 2005 at 16:47 | IP Logged |   |
          Just FYI - I was haveing to many problems with the motion detector - it was just too flakey. So I simplified these further and reduced the functionality a bit.
           | Posted: March 24 2005 at 17:57 | IP Logged |   |
 My occupency flag no longer sets the thermostat - I do that manually. I do however let PowerHome turn down the thermostat.
 New logic is something like:
 Trigger: A16 On  (motion detected)
 - Set Occupied = 6
 Timer: Every 5 minutes run:
 - Occupied = Occupied - 1
 - If Occupied == 0 & Thermostat is On
 - - Turn thermostat off
 Basically this means that 30 minutes after I leave the room PH will make sure the heater is turned down.
 Besides the thermostat there are a number of timed events that only run if the Occupied counter is > 0 - this lets me do things only if I'm in the room (or have been recently)
 Not quite as elegant as originally designed, but it does work reliably.
