PowerHome Programming
Subject Topic: Basic - Beginner Questions Post ReplyPost New Topic
Gadgets
Posted: February 05 2008 at 22:53 | IP Logged Quote Gadgets
Now I have finally gotten some things to work correctly in PH, I have some basic questions that will help me be quicker at getting things to happen.. maybe.
These are do be assumed all devices have been added (and based on X10):
What order to things have to be done in? Like Triggers, can they directly control a device, or do they have to go through a macro?
If I want an event to be triggered by an incoming X10 signal, what are the steps to do so
Do macros have to be made for all devices so they can be controlled?
How do you connect more then one formula together? for example lets say I want these two things to happen for the same event:
ph_devicecontrol(commands here) then ph_tts(string here) can I do this sort of thing, and if so how?
ph_devicecontrol(commands here) + ph_tts(string here) is that the correct way of doing things??
Friends, don't let friends install Norton Products
Back to Top View Gadgets's Profile Search for other posts by Gadgets Visit Gadgets's Homepage
theowl
Posted: February 06 2008 at 00:31 | IP Logged Quote theowl
To me, the order depends on how much you want to do for the event. For example, if I want to hit a button (K2-ON) and just have a phrase spoken ("Oh NO! The BOSS is home!"), I can do all that with-in a trigger by setting it up to fire on K2-ON and setting action as a raw formula ph_tts("oh no. the boss is home.").
If I wanted to add a light-on to that, I could still do the raw formula but use + ph_device....
(So, it's + to join two things)
However, my greetings system uses a trigger and macro since it's so much more complex. First, it has to check if door1 and door2 opened within 60 seconds of each other. Which door opened first so PH can figure out the direction the person is traveling. If they are coming in, play the greeting, turn the lights on, read off any announcements.
So much to do that I had to put it in a macro that is called by the trigger.
I also have a macro to remind me to do stuff which is called from a timed event. The same macro is also called by a trigger if I enter the room where I need to do the job (ie: Take out the garbage can trigger if I walk in the kitchen AND at 10am on Monday).
Hope that helps
Back to Top View theowl's Profile Search for other posts by theowl
Posted: February 06 2008 at 07:20 | IP Logged Quote TonyNo
You may also want to check out an old-ish tutorial that I did.
Tutorial
Posted: February 06 2008 at 14:03 | IP Logged Quote dhoward
Brian,
Triggers don't have to directly call macros. They can call a raw formula or device control string as well.
Laying out your Home Automation plan takes practice and will usually change quite a bit over time. What I try to do is come up with all of the "actions" or tasks that I would like to have performed. If these tasks are more involved than just simply announcing a TTS or turning on a light (ie, multiple steps that I may like to have performed as a result of several different "triggering" actions), I will generally create a macro. I usually try to do this first, but sometimes it comes after.
Once Ive gotten my "actions" or macros fairly well defined, then I'll determine what "triggers" will cause the actions to fire. Sometimes, the trigger is a Control Center button press, in which case this is setup in the Control Center section instead of the Triggers screen. Sometimes, the action is based upon time (as the primary factor) and this is done with a timed event.
If you're working with raw formulas (and functions), then you've got it. Just add them together with a '+' sign and you're good to go. Check out the wiki "Formula" and "Variable Substitution" sections (they go hand in hand) for a little more in depth on this.
Gadgets
Posted: February 07 2008 at 22:46 | IP Logged Quote Gadgets
dhoward wrote:
Brian,
Yes absolutely it helped. And it confirms some of what I thought, and clears up others.. thank you!
