Posted: September 23 2007 at 23:16 | IP Logged
If the unit codes "line up", create X10 RF In triggers for M On, Off, Bright and Dim for Any unit codes, then pull the unit codes out of the [TEMP3] variable, and use that in a formula action...
On:
ph_x10( "your controller", "A", [TEMP3], 0 ) + ph_x10( "your controller", "A", 102, 0 )
Off:
ph_x10( "your controller", "A", [TEMP3], 0 ) + ph_x10( "your controller", "A", 103, 0 )
Bright:
ph_x10( "your controller", "A", 105, 10)
Dim:
ph_x10( "your controller", "A", 104, 10 )
Just four triggers for the entire M house code.
Edited by TonyNo - September 23 2007 at 23:20
