        | patrickm Senior Member
          Hello,
           | Posted: May 29 2007 at 14:44 | IP Logged |   |
 |  I would like to write a macro that would be able access a 2d array for the parameters i.e. device and duration.  I am trying to avoid having to write very long macros with specific variables for each device and duration in the macro and just use a loop with a pointer to an array.
        | TonyNo Moderator Group
          Arrays are only supported in scripts. Sounds like you may be able to handle that, though, since you mentioned "pointer".
           | Posted: May 29 2007 at 20:54 | IP Logged |   |
          Are the Insteon functions supported from within scripts directly?  I didn't see any listed in the help file, but I believe the help file hasn't been fully updated yet.
           | Posted: May 30 2007 at 01:21 | IP Logged |   |
          I believe that you can use ph.formula( ph_insteon(xxx) ) for that.
           | Posted: May 30 2007 at 08:11 | IP Logged |   |
        | eHomeCreations Groupie
          Arrays are tables. Can you just create a table and use that?
           | Posted: June 04 2007 at 02:38 | IP Logged |   |
 --Steve       http://www. ehomecreations.com
          I searched for tables in the help file and didn't see any references.  A table would work if they exist.
           | Posted: June 05 2007 at 12:38 | IP Logged |   |
          There is a User Table (UserData1) that you can populate.
           | Posted: June 05 2007 at 19:54 | IP Logged |   |
          I assume that is accessed by sql commands?
           | Posted: June 05 2007 at 23:48 | IP Logged |   |
          Sorry! Yup.
           | Posted: June 06 2007 at 07:10 | IP Logged |   |
