        | bpmcgee Newbie
          Hi,
           | Posted: May 02 2007 at 14:10 | IP Logged |   |
 I'm having a problem with getting the "on" insteon command to work in my macros.
 If I use the "on" command by itself from the other windows, it works fine.
 If I use "fast on" in the macro instead of "on" it works fine.
 It's happening with all 3 of my devices.  They all show 100% comms success.
 I'm getting an ack from the device.  I don't have the exact text here, but the interesting note is at the end of the ack it says "On at Off" instead of "On at On" as a normal ack would.
 Any clues?
 B
        | nadler Super User
          You need to put a number (1-255) in the last field that's labeled "Send Keys/TTS/Dim/Formula" when you use Insteon ON rather than Insteon FAST ON.  The number represents the brightness level.
           | Posted: May 02 2007 at 16:51 | IP Logged |   |
        | bpmcgee Newbie
          Ah, thanks!  What do I use to get it to resume it's pre-set dim (local level)?
           | Posted: May 02 2007 at 16:55 | IP Logged |   |
 B
 Edited by bpmcgee - May 02 2007 at 16:55
        | TonyNo Moderator Group
          I think that you would need to read and store the level before changing it if you want to do that.
           | Posted: May 02 2007 at 18:43 | IP Logged |   |
