        | nadler Super User
          I notice in the manual for the new smarthome software, Houselinc, they have double click implimented.  This allows you, for example,  to turn off all lights in a room by double clicking off or just the controled device if you press off only once.  Any chance this can be implimented in PH (without flags and macros and such)?
           | Posted: August 11 2006 at 09:53 | IP Logged |   |
        | TonyNo Moderator Group
          An Insteon double-tap sends a Fast On or Fast Off; you can set up triggers to do whatever you want when those are received.
           | Posted: August 11 2006 at 12:38 | IP Logged |   |
        | nadler Super User
          Wow.  I've been using Insteon since day 1 and PH for a long time.  I never knew that.  I knew they were different but never realized it was because of the double tap.  I will have to put that into my PH tips and tricks document.  And, of course, it just continues to confirm that Dave is WAY AHEAD of smarthome's application.
           | Posted: August 11 2006 at 12:51 | IP Logged |   |
 Thanks (again).
        | ginigma Senior Member
          nadler,
           | Posted: August 16 2006 at 14:42 | IP Logged |   |
 |  Anyway a PH newbie could convince you to post your tips and tricks doc?
