        | TonyNo Moderator Group
          Can the Command drop-down be populated with only numbers (instead of Command 1, Command 2, etc.)?
           | Posted: November 25 2005 at 08:27 | IP Logged |   |
 This would allow typing in values instead of scrolling to select them.
           | Posted: November 28 2005 at 19:54 | IP Logged |   |
 I'll look into this.  Should be easy enough.  I'll check on it tonight and see if it can even be fixed with a SQL statement.
          Sorry Tony...no SQL.  The data is contained in the all_value view which cannot be updated in the runtime dynamically.
           | Posted: November 28 2005 at 21:05 | IP Logged |   |
 But...the change is in so it'll be available in the next beta.
          Whoo hoo!
           | Posted: November 29 2005 at 08:08 | IP Logged |   |
 Any updated estimate for release?
          Im hoping for the next couple of weeks.  Ive nearly finished the Insteon support (however, Ive discovered a bug in the sendx10raw...it doesnt send any X10
           | Posted: December 02 2005 at 22:13 | IP Logged |   |
 |   ).  SmartHome has promised a redistributable version of the Device Manager shortly so Im going to try and wait on that.  If it's not soon, I'll just go ahead and release without it.
          Sounds good.
           | Posted: December 03 2005 at 08:21 | IP Logged |   |
