PowerHome Bug Reports
Subject Topic: More Trouble with PHUPG.EXE Post ReplyPost New Topic
seyler
Posted: October 27 2003 at 16:45 | IP Logged Quote seyler
Hi Dave.
I have just installed 1.02.2.  Prior to this I was running 1.02.1.  After the upgrade, I tried to run PHUPG.EXE and encountered the following error:
PowerBuilder Application Execution Error (R0021)
Application Terminated.
Error: Bad runtime function reference at line 20 in function f_decodepass of object phupg.
I have rebooted and tried several times with the same problem.  I have checked in the PowerHome directory and each .PBD file has the same timestamp as PowerHome.exe so I don't think that those files are out of sync (as was indicated in a thread entitled "Having Trouble.")
In order to bring the application back online I tried re-installing 1.02.1 but received error "Mismatched version with PHFN.PBD."  So I re-installed 1.02.2 - but I still have the same problem with the database upgrade utility, and of course without upgrading the database I get the following error when attempting to launch PowerHome:
Your database version is 1.02.1 and this verison of PowerHome requires version 1.02.2.  Please run the appropriate upgrade utility and try again.
So as you can see I am dead in the water - my wife's greatest fear... the house crashed.  My God, we are using manual switches for lights (when we can find them.)  Now she is afraid that one of these days the house will tell her "I'm sorry, I can't do that."  And she won't be able to leave the house.  Of course, we both know this will never happen (right?) -- but it's hard to convince her of this when we have to resort to manually turning on light switches and using the "old" remote controls for the home entertainment center.
Please help!
Thanks.
Steve
Back to Top View seyler's Profile Search for other posts by seyler
Posted: October 28 2003 at 10:32 | IP Logged Quote dhoward
Steve,
Received your email with your attached database and upgraded it for you.  Hopefully you'll have it shortly.
Not sure why you encountered a problem on the phupg
When going back to 1.02.1, it looks as if the phfn.pbd from the 1.02.2 install was not overwritten.  If you were to first uninstall 1.02.2 and then reinstall 1.02.1, you should be fine.
Also, take a look at the 1.02.2.2 beta.  Its stable and includes features that you may be interested in.
I know what you mean about the house.  Ive got things automated to the point that I can barely function when I take the machine down for any kind of upgrade.
Hope this helps and let me know if you have any problems with the upgraded database.
